On 8/10/2023 at 11:11 AM, Murray_Calavera said:
If you think your local water is bad, I pray you never experience bore water in an outback town lol.
You're not meant to drink the bore water, not until you filter it at least :P
but Bore water is typically tastier than the shit that comes out of Dubbo's town water :P
  • Haha 2
It was crazy the amount of locals I met that drank the bore water straight out of the tap =/
Its funny now that I think about it, all the day trips I did into Dubbo, I never drank the tap water. I just drove the 4 hours each way and didn't say the night in Dubbo, so didn't really have the chance to be exposed to it. Based on the size of Dubbo, I always assumed the water would have been like Sydney water, guess not lol.
My Pop used to live there (He's now passed), even Nan wouldn't drink the water, nor would anyone else. My cousin has lived there now for about 24 years. Still won't drink Dubbo water, ha ha ha
It has the weirdest flavour!
That being said, we've also had times in Brisbane where the smells, and tastes, like dirt. Normally after a flood, and its from extra "totally safe" organic water matter up stream of the water processing plants.
11 hours ago, MBS206 said:
Hey Dose... Time to get to tuning...
Preset to 350kPa but we can ramp that bad boy up. Get you some more PSIs and more flows!!!
Full send it, will need to install an inline gauge to determine the pressure though 😂
I've seen the way you drink...
You'll drown...
My yesteryears of agency life are long gone!
I get tipsy off 2x beers now, cheap as it gets.
  • 3 weeks later...
Making the shit box, less shit by about 0.1%
Started by taking out the harness bar, seats, trim, parcel tray.
Going to change the RCA leads as the current set has a bolt through it lol. Then upgrade the headunit, install 2x baby seat tether points (turns out buying them new is cheaper than trying to buy them on FB or off a wrecker, funny right?). Will then leave the trim and shit off, and remove the stupid dark tint and replace it with something normal and legal.
After all that, will then go back to fab for a few small changes, such as a better catalytic converter and the catch can Venturi.
If anyone is reading this and wants to buy this shit heap, please buy it off me so I stop spending money on it.
  • Like 1
Swaps for a big block Yaris, I know what I got....
  • Haha 1
Nah, you just ruined that car by putting that pioneer headunit in your car...
But legit, I've got a bit of a hate case with Pioneer now. Used to solely use their head units. However, the last two double din units. First one started doing weird shit at about 18months old with Bluetooth. Legit thought it a phone issue more than anything. 24 month mark and it did the same weird thing. Then restarted, then turned itself off. Never worked after that. Pioneer didn't want to know about it.
Drove for 12 months with no music in that car.
Put another double din in from pioneer. 18 month mark, has started doing the same thing.
Haven't driven said car in 11 months now, but I suspect the head unit won't have much life left, IF it turns back on at all...
  • Haha 1
I am really enjoying not working at the moment.
When my daughter goes down for a nap, I have a bit of a window to cook/clean/do shit/do a shit/work on the shit box.
Today, I decided it was time I added a 2nd SSR for my PWM fuel pump setup. Previously had both pumps off the 1x SSR, which is totally fine, however knowing my luck the SSR might just die so always good to have some kind of redundancy, even if it's just 1 out of 2 pumps running.
Still thinking how to route the wiring, job for tomorrow.
Good setup for WTAC!
PWM setup very pretty!  Still a little bit over my head that stuff.  Need to sit down with no other distractions and get my head around it all.  I've got the PWM's for when I eventually put mine all back together.  Might have to lean on you for assistance.  Don't tell me know as by the time it's relevant I will have forgotten!
  • Like 1
Add it to your list of things to do 😂
More than happy to explain it and take you through it, alternatively you could use a PDM and double up outputs to allow 50A loads.
I went down this route because I set it up years ago before PDMs were a common thing.
Been meaning to tidy it up for years, and install a 2nd SSR. Found the time to do it now, since I'm not working (on paternity leave). It's amazing how motivated I am now because I'm not working my normal job. It's like my corporate job drains my soul of everything else.
Today, finished off the wiring from SSR to fuel pumps, I integrated fly back diodes into the wiring for sex appeal, instead of running them externally over the surge terminals.
  • Like 3
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
