35 minutes ago, Murray_Calavera said:
What's the news?
The ic7 will be firmware updated to allow 2-way CAN communication allowing additional inputs for the ECU. It will also be a master device now, so I believe it can act as a controller for the PDM. You can also customise logos etc.
  • Like 2
Pretty much no need for an I/O expanded if you have a dash.
Also, there may be a new Haltech dash coming in the future, I hope they update the housing lol.
That's the only reason why I didn't buy an IC-7, I know it's silly, sure it's ugly but the car itself is pretty ugly too LOL.
Yeah, I think they are bringing out a bigger display. I think a 10”??
the ability to programme the buttons on the display is pretty good too.
One can hope, if not I'll just get an IC-7 and stop sooking.
Loaded up the latest firmware, oh wow... went for a drive and it's like I've setup Alpha-N and MAP compensation. I thought the transient table I built was good, but wow... this just brought it to another level.
@R3N3 this is how I make the car brap lol.. sounds better than rotational idle
Nice little timing hole lol
And for the idle control you want it to not much between -50 ~ -100 RPM
Awesome! I will compare the sound. I ended up dialling in the launch and rotational idle 100% many bangs and flames were had. Although I’m a little worried about my stock oil pump gears…
  • Haha 1
1 minute ago, Dose Pipe Sutututu said:
Didn't you want to build a new motor? LOL.
Haha, true! The plan is to switch out a working motor with another working and better motor…
Last time @admS15 used his launch control, he lost a turbine LOL.
On 08/10/2023 at 1:38 PM, Dose Pipe Sutututu said:
Washed the shit box, forth wash since the start of 2021 when the respray was done.
As much as you like to complain about it, your car is a looker! Is this photo with new tints? Which ones did you end up going with?
It's on my list of things to do, though not at the top. Being able to see nothing at all out of the windows when it's dark and wet outside gets old very quickly.
I work in IT, complaining is a prerequisite LOL.
I went with a legal 35% tint, it's some ceramic bullshit (apparently good?). Got it done by Tint a Car in Moorebank.
  • Like 1
Haha, fair enough. Yeah ceramic is meant to be better with keeping off heat. Or so I learned doing all of five minutes of research.
But for some reason the extra photos you included in your post that show the new tint don't load.
    • Could someone post some pictures of the factory Jack , tools, spare tire and how they were in a 1998 ER34 2 door skyline originally?
    • UPDATE: Hi all!  As we are getting towards the end of this thread where I’ll showcase final dyno numbers and graph, I wanted to provide an update. Tao from HyperGear has done an amazing job building the custom divided T3 housing for the G30. Communication was flawless, price was great, and now the housing is estimated to arrive in 7-10 days! Very very pleased. I must add, if someone is looking for an affordable turbo and end up reading this thread, I would recommend HyperGear. Genuine brands are the way to go as their proven reliability, predictable performance, and there’s a plethora of information available for specs, flow, and more. This HyperGear recommendation is based on their excellent communication, dedication, and willingness to listen to their customers. I particularly liked their ability to create custom adaptations tailored to specific needs, which is a HUGE benefit over other brands. And if we consider the HyperGear provided dyno results, it adds reassurance knowing their turbos can compete against genuine brands. Next update will be after the dyno!
    • I've previously seen people post up "dress up bolt kits" for RBs but don't remember seeing them specify the full contents. I can only really suggest you grab the verniers and start measuring, and keep in mind the cam cover and timing cover bolts are both quite specific with a wider unthreaded section where the bushes sit, that will make it hard to get aftermarket replacements which tend to be all thread (set screws) or for longer bolts a flat section with a shorter threaded section at the end
    • I believe there was a similar one posted by @duggyphresh. They were re-routing their battery positive cable in the way I am also trying to achieve. Sorry, I’m new to this forum, so was a bit late to the party by a few months and so reignited the old thread, as I wanted to know how they got on with doing it.
    • Wasn't there a thread on this very subject just a few weeks ago?
