Drove it tonight, gave it a bit of a squirt on the new motor. Does feel strong, but haven't given it a beating yet as it's still the 1st batch of oil.
Will dump out the oil then drive it harder this weekend :)
Not a bad turbo, comes on (gate pressure) about 4000rpm, from the trace you can see 0.8bar of boost by 3600rpm. Mind you this was all in 2nd gear. No 3rd gear squirts yet hehehehe
@Piggaz told you I was going to give it not pussy it around!!
  • Like 4
50 minutes ago, niZmO_Man said:
But does it dose?
not VL dose, but it is because running low boost and also has a stainless intake..will take the car and get some fab work soon ish :)
Haven't driven the car since but installed a modern head unit with bluetooth for hands free life :)
Some modern features for an prehistoric car.
2 hours ago, sneakey pete said:
If you can hear the radio you're not driving it fast enough...
That's what i tell myself anyway, need to get mine working again...
Haha its got some decent audio, Vifa splits and a DD ported sub. At the back there is a 4 channel and a monoblock to power the speakers lolol.
So late arvo yesterday, dropped the oil and put in fresh 15W50 Penrite Racing and decided to check the base timing. It was a whole 4 degrees off. Explains why the car had a bit of a boost creep running stock gate pressure.
Fixed that, then took it for a spin (in between that fixing the fuel table which didn't require much change from the old motor setup). Got the AFRs a bit leaner so now its hitting 11.7 and flat lining.
And yep, I raised the boost too haha.. Running it in at 1.2bar of boost with crap all flat timing it's baking shitty 245 section Dunlops. Took it to Mexico and wound out 1st 2nd and 3rd, think I'm starting to hate the car less. Followed by that ended up at my mate's shop in South Mexico followed by a session of donuts to bed in the motor further. Gave the keys to the other boys at for a spin too. One didn't mind the lag as the motor revved out to 8.3k the other said was a bit too laggy for his liking but nevertheless still put a smile on everyone's face.
Late last night thought I would try to download the footage from my dash cam, turns out the memory card is corrupted :(
  • Like 2
I'm running in this car a shitty Laser branded dash cam. It's the same as the G1W you see on OzBargain.
Also isn't the first time it has corrupted a memory card. Instructions clearly state only use memory cards in this list, clearly I'm not lol.. Have a SanDisk SD card in there it doesn't like.
I don't think it matters, I've got an older GoPro4 and a quality SanDisk card and it never seems to capture anything when I'm doing illegal stuff, it's really odd.
Ordered 2x 3.5" v bands, came next day.. Woo! (One pictured)
More exhaust mods, 3.5" into a 3" axle back isn't going to be optimal for 400kW+ worth of exhaust flow. Gotta open up that shit
  • Like 1
A bit of raw data from the car, we can see it's making boost within 200ms or so from gear changes. Not bad transient response :)
It's no EFR or GTX but for what it is it will make many GT-R owners with twins pretty sad lol
Haven't had the chance to give it a full belt and do logs because of the long weekend
  • Like 1
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
