They're available from Nissan! I was able to buy a GTR (R33) one.. relatively* recently. Perhaps this stopped now but I bought mine ... relatively recently.
I believe the 300ZX one has a different knee-point which is more rear biased, which I think the HFM one echos.
So after some Chat GPT (yeah I know lol..) it turns out that the R35 GT-R BMC conversion may not be suitable for our shit boxes as it splits the fluid 60:40 instead of 70:30.
When looking at possibly doing the 370Z conversion, it seems it's quite similar to how the R35 GT-R booster & BMC mounts up, however after some additional digging the 370Z BMC bore is the same size as a R33/34 GT-R BM57 one.
Brake Pressure Split:
  • Nissan 370Z: The typical front-to-rear brake pressure ratio for the 370Z is approximately 70:30. This is designed to handle the car’s weight distribution and performance characteristics, favoring the front brakes heavily due to weight transfer during braking.
  • Nissan R33 GT-R: The front-to-rear brake pressure ratio for the R33 GT-R is also typically 70:30. However, this ratio is tuned for the GT-R's specific weight distribution and dynamic performance, considering its all-wheel-drive system and higher performance expectations.
Despite having the same nominal 70:30 ratio, the actual distribution of braking force in practice can be different due to other factors like vehicle weight, ABS and EBD systems, and brake component sizes.
Bore Sizes:
The bore size of a brake master cylinder affects the hydraulic pressure generated within the braking system and can vary between different vehicles based on their braking requirements.
  • Nissan 370Z: The brake master cylinder typically has a 1-inch (25.4 mm) primary bore. The secondary bore can vary slightly depending on specific trim levels and brake options, such as the Nismo version or those equipped with the Sport Package which features larger brakes.
  • Nissan R33 GT-R: The brake master cylinder in the R33 GT-R generally has a 1-inch (25.4 mm) primary bore as well. Given the GT-R's high-performance context and advanced braking system, the bore size is designed to provide sufficient hydraulic pressure for its braking needs.
Comparison:
  • Brake Pressure Split: While both vehicles use a similar 70:30 ratio in the brake master cylinder design, the actual operational distribution might differ slightly due to differences in brake system components, vehicle dynamics, and tuning for each model.
  • Bore Sizes: Both the 370Z and R33 GT-R use a master cylinder with a primary bore size of around 1 inch (25.4 mm). This similarity helps in providing robust hydraulic pressure for effective braking.
Additional Considerations:
  • Braking System Design: The overall brake system, including calipers, rotors, and the master cylinder, is designed to work as an integrated unit. Even with similar bore sizes and pressure splits, the performance and feel of the brakes can differ due to variations in brake pad composition, rotor size, and ABS tuning.
  • ABS and EBD: Both vehicles are equipped with Anti-lock Braking Systems (ABS) and Electronic Brake-force Distribution (EBD), which further modulate and optimize braking force between the front and rear wheels dynamically, depending on driving conditions and brake demand.
In essence, while the 370Z and R33 GT-R have some similarities in their brake master cylinder specifications, they are tuned to meet the specific performance and handling characteristics of each vehicle.
TL;DR, just use a R33 BM57 and call it a day.
  • Like 1
FYI the BM57's in GTR do split 60/40 and they knee over from 50/50 at a certain pressure. (I found this after extremely painful googling awhile back)
The Z32 BM57 also splits 60/40, but the knee point where the 50/50 becomes 60/40 is at a higher pressure.
The S15 BM50 is the one that splits 70/30 I think?
They are also 17/16" size, and the plug fits, no downsides :D
  • Like 1
Yeah less mucking about grinding down the firewall, using brake line converters, etc.
Just send it with an original BM57 and call it a day.
  • Like 1
3 minutes ago, GTSBoy said:
So the message is I probably want an S15 one.
I actually think the S15 is 80/20. I know I said 70/30 before but perhaps that is the GTT/GTST one. I wanna say it's the BM50 or BM44. I have one for sale if you want it GTSBoy, try your luck. For some reason the R34 GTT one is actually unlabelled, so it's a BM??????
@Kinkstaah HFM will have a spicy BF sale in November, might be a good time to load up on the adaptors, new lines, etc.
Then may the best grinder win lol.
Oh I have mine all sitting in boxes ready to go, two sets of rotors, four sets of pads and caliper rebuild kits. They send a survey asking me if I had installed them months ago :p
Grinder not necessary to fit the fronts, and not *really* for the rears. They have some good simple videos on how-to.
I don't understand brake lines but from what I understand... somehow... OEM lines work, even though people say 350Z and 370Z use different banjo bolts, so it's possible 350'z had some different setup that Nissan changed to the 370Z/R33/R34 system?
....though are a little short, but past-me made a new bolt hole to bolt them to to reach my current fronts so I should be okay... maybe.
In any case HFM don't sell any *different* line kits for R33/R34 front brakes than they do for the 370Z kits. So in my mind they must be compatible or they would have different products made to suit the different calipers.
Please test and confirm for me kthx.
  • Like 1
It's more so I'm using the 1x piece line from HEL that goes from the body to the caliper. There's no middle block/mount like the HFM ones or the GKtech ones.
There are certain angles/suspension compression where the line actually slightly contacts the ARB.
Below of how mine sit (not my photo):
How I want it:
I hadn't got that far, my main worry was the connection to the actual calipers themselves. I'm just using new (ish) stock brake lines in the stock setup. I've just had a stud welded to the knuckle that is a little lower than the original stud (so my knuckles have two studs each side) to not have it be stretched so far in previous BBK setups, so the "block" (in the second picture) mounts a little lower for me and I hope I don't need to change anything.
I may have even changed the connection to the calipers in the past and have since forgotten I did that. I may not have. Guess how I'm gonna find out.
Source: hopium
  • Like 1
Pulled out this pile of shit, will be refreshed soon enough.
Had coolant hit my face and I accidentally tasted it.
It's sweet.
  • Like 1
  • Haha 2
It's sweet.
Be happy it wasn't old auto gearbox fluid. That shit, is disgusting!
  • Haha 2
Cost of living crisis is real, bought Aeroflow fittings to run the water return from the turbo hardlines I made, back to the thermostat.
May regret buying Aeroflow, as the rest of the car is Speedflow 🥲
New on top, old on the bottom.
New with old sleeve, old with nothing.
New firewall grommets. I need a new hobby.
Also made my ChynaFlow turbo water return line back to the thermostat housing. Could have just used a length of EFI hose but no, I wanted braided but on a budget so bought Aeroflow junk. Might regret soon.
  • Like 4
On 14/04/2024 at 7:07 PM, fletch rb30 said:
Are you returning your turbo coolant to that fitting below the head gasket?
This comment has kept me up at night (amongst other reasons).
I've found a way to solve this mess, and that's to return the water line all the way to front where the OEM barb goes to the bleeder (where the thermostat housing is).
Funny enough, old GReddy plenum instructions just stated to plumb it into the fitting I had initially chosen.
Anyhow this is what I've knocked up. It connects from the turbo coolant return hard that goes behind the head (I made this, similar to the half rubber/half hard line OEM one). Then sweeps down and runs along side the plenum to the thermostat housing where there's a 90° fitting which goes into a 3/8" barb. I originally bought a female 3/8" to 6AN fitting to convert the OEM barb, but it wouldn't go over.
So yeah we landed at this.
Fitted, will adjust the angles of the fittings once I fit up the loom.
Under plenum, really wanted to convert that barb to a 6AN but yeah nah, wasn't a true 3/8" so that conversion fitting didn't work.
Less messy now, the coolant hose mess is now gone!
  • Like 1
    • Heres another fitment photo. redrilled the pattern to 5x112, and threw my audi´s rims on. had to touch the upper control arms with grinder, because the "sharp corner" was sticking about 2-3mm on the tire path. i have the "fender lip" mostly cut off, otherwise these (too) would contact with it. 20x9.5 ET25 rear    265/30 20x8.5 ET20 front    255/30 they are temporary, and look too big for the chassis. searching for 19s to it.
    • From experience, it will come back to bite you haha.
    • Background: my BMW 225i hatchback (rebodied MINI/X1) came with 3x RE003 and 1x Goodyear Asymmetric something. The RE003 roared and slid around, the Goodyear side was quiet and grippy. Definitely my car was thrashed before it got sent to dealers. My brother also got RE003 all round on his old VA WRX STI, I wasn't impressed with them, car was loud so can't comment on noise. Anyway, Hankook stopped making/updating V12 Evo2. So bought S1 Evo3 runflats. Great daily duties tyre and not that harsh ride. Tyre reviews site/youtube rated them as best stopping in the rain and I believe them. Next set, Goodyear Asymmetric 5 non-RFT. It beat PS4 in tests and is like $100 cheaper, so put them on. Great tyre, more grip then S1 Evo3 but a tad noisier as expected, still rocking them. Next set I am looking to go runflats, probably the new Hankook Evo. Although the new Pirelli PZ5 did well in tyrereviews test. Or go Goodyear Asymmetric 6 which was top tyre last year. The V12 Evo2 on my gen5 Liberty GT wagon did great in cold condition (drove to snowy mountains for a day so my husky can feel his ancestor's roots). Super impressive performance for $120 each lol. Never skimp on tyres, brakes, suspension. There's old pics of my R31's crappy random brake pads bending in the caliper at Oran Park track day somewhere around here. Anyway, my 2 cents.
    • I said "Matlab clone". I could throw one onto one of my linux VMs. Probably only take 10 or 20 hours to sort out the dependencies, relearn how to use it, etc etc.
