14 hours ago, timmy_89 said:
Mine aren't quite this lumpy anymore, still but definitely more noticeable then Johnny's "street" car :P
In your case its probably just a misfire as you forgot to plug in an injector :laugh:
  • Haha 3
18 hours ago, timmy_89 said:
y u no lumpy
"Stock" car bro lol..
Also found out why my EBC was being so lazy, somehow the lines going to the EBC had dirt in them lol. Will test the car later tonight and hopefully won't need as much DC to hit my boost target.
On 01/03/2018 at 4:38 PM, NEO25T said:
Hmmm there must be a good update brewing?
Found out each time I spin the motor past 8k it spits the PS belt lol.
Was overseas for 1.5 weeks, will work on the croc of shit soon :)
  • Like 2
Decided to start to the car today, has been offline for nearly 2 weeks.
Started first go, and yes the tacho is going mental - either it's going into the bin OR I find money out of my arse for a dash :D  Also for those with a good eye, yes the FPR shows 3bar with the vac on, but weirdly enough when the car warms up it will drop to about 2.6 bar, i.e. 3bar without the vacuum attached.
Note the popping and volume changes are not from the car itself, it's my phone (LG G6) doing weird shit.
  • Like 3
  • 4 weeks later...
Flex Sensor Fridays...
Deleted the karnt, had fuel pressure fluctuation issues and turns out this was the problem.
Because I run a Wallahbro 460L there's a fair amount of fuel being circulated back through the return. With the flex sensor in line, I couldn't screw down the fuel pressure less than 2.6 bar (that's with the entire bolt pulled out of the FPR).
Now that it is out, I can drop fuel pressure below 2 bar.
For now it's out until I re-think my fuel system through.
not a bad idea :)
But I'm planning to do it between the surge tank's overflow back into the main tank, as the lift pump I'm planning to use would be only a DW200 so there won't be much of a problem where as now I'm using a Wallabro 460L and it's flowing quite a bit of fuel around the system.
Just now, Robzilla32 said:
But if you that, is the sensor measurement still accurate enough?
plenty accurate, there's still going to be fuel flowing through it :)
  • Like 1
1 hour ago, Robzilla32 said:
But if you do that, is the sensor measurement still accurate enough?
Put a 1-2psi valve in the by pass. That way the sensor gets all the fuel it needs and as soon as there is a slight rise in pressure, the excess goes via the by pass.
  • Like 1
1 hour ago, Dose Pipe Sutututu said:
not a bad idea
What if there is very little/no fuel coming back from the surge tank. Sensor gets no fuel flow, reading goes stupid, engine doesn’t know what ethanol content it is. Not a smart place for it IMO. Have seen it on another car and funnily enough it got moved.
Good point, there will be times the surge overflow will dribble out fuel. If that's the case I'll just pop it on the feed side, tank -> lift pump -> flex sensor -> surge tank.
My car had fuel pressure issues initially after putting in the new Walbro 450, it flows _a lot_ of fuel. My workshop spent a bit of time troubleshooting it and ended up swapping the stock reg for a Magnaflow, which settled it down.
Good riddance of that flex sensor, who needs anything but ethanol anyway ;)
I had fuel pressure issue with Walbro 460, mine was with a restrictor in the factory fuel hoses (R34 non turbo hose setup). I still have the stock jet pump in the tank too, going to drill that out a bit soon too.
You have a radium venturi dont you dose?
Just a stock venturi Phil, that will stay as I will be running a DW200 lift pump in future.
I have a Radium Fuel Pulsation Damper (FPD) which has helped with fueling on cruise areas of the map. Before I had to dial in heaps of fuel to remove the sputtering and now those issues are some what gone. I haven't had the chance to drive the car after the flex sensor was removed but I can only imagine it would run a bit better as the FPR is actually working properly now.
  • Like 1
1 hour ago, dr phil said:
Did that replace the ones in the engine bay? There are two right - one bolted to the side on the return line, and one on the fuel rail?
Yes that is correct only for the R34 GT-t, R33 GTS/-t only had them post fuel rail.
Mine is deleted because I placed my flex sensor there initially but after all the issues its a straight hose from the FPR to the return.
  • Like 1
    • Curious to why you're not getting Jesse to do the exhaust, seeing that he has just done 2 GTRs with Aes valves.
    • What extra parts are you thinking you'll need to run e85 compared to e30?
    • I'm not aware of e30 in Australia, but I'm pretty sure e85 is still around. You really want a setup with an ethanol sensor so you can run any mix of ethanol depending on what you can access. Fuel Check NSW app shows 14 site in sydney metro with e85. What are you adding, will you put in bigger turbs too? Apparently the wastegates are pretty small and can't bypass enough as you run more boost.  I'm sticking to 1.3 bar with 98 on the standard turbos with my tune on advice from the tuner, and boost drops significantly in the top end; apparently larger turbos with larger wastegates are needed to get anywhere meaningful from there.
    • Amazing work Duncan! It is never easy to pick up someone elses project and work all the parts out that are missing
    • Hey Ppl,   I am about to tuned my Infiniti Q60 with E-85 and if you can tell me some location where I can top up my car that would be great.   But my other question, is E-30 available because this tuned requires less mods parts and any info you can offer would be greatly appreciated too!!
