And as it was running ok, she's off the road again lol. Nissan life, spends more time off the road than on the road.
Photos are self explanatory and for the not so visible I will be running 2x Wallahbro 460L/h pumps off 2x SSR for PWM. This should allow me to control the fuel pumps based on engine load. Benefits of this are tremendous, less heat generated, less noise when doodling around, lower current drawn when engine is at lower RPM and not to mention it is just cool lol. This is one of the many reason why I've moved to a Haltech Elite 2500, although the Adaptronic is more than capable for 90% of the applications out there. Thinking about it hard enough, I could have even used the boost solenoid output of the ECU to control the fuel pumps :)
(Yes we are a Haltech club, that's Henry from Hensperformance, small one man band that turbo charges lancers and mirages, asked him to help out to get the car on the road quicker)
  • Like 3
16 minutes ago, iruvyouskyrine said:
What SSR will you be using?
Just the Jaycar shit, big enough and fast enough 1 ms (0.5 ms release and 0.5 ms on) response which translates to 1000hz. More than fast enough for what I need it for.
16 hours ago, TimmyMA70 said:
I just finished reading your build man, really good read! Heaps of detail too Love it.
Cheers man! It has been a shit journey but I'm nearly there!
Also in other news, after removing about 10kg worth of amplifiers something needs to go back in so I've opted for small and lightweight Clarion Marine amps, perfect for the boat.
These will be fitted on the LHS next to the battery where as my old set up had 2x large amplifiers stacked on top over the fuel tank access.
  • Like 1
51 minutes ago, WantGTR said:
This thread was great until this crap about amplifiers
I might look Asian but deep down inside I'm a Leb.
  • Like 1
  • Haha 2
You need marine speakers on the outside of your car so everyone can hear your hectic choonz as you drove through cabramatta
59 minutes ago, niZmO_Man said:
Need the hardstyle to drown out the fuel pumps :P
fuuark need to muzz in the car too, get featured on Muzz Chop Appreciation group man!
shuu, stereo so loud don't even need speakers outside - will give the Ivy a good run for noise
  • Like 1
  • Haha 1
^lol for a state that doesn't allow shots after 12am, no entry/re-entry after 1:30am I wonder why everyone is angry :)
Also good way to kill the economy, because of the lock out laws the statistics look great on paper and the politicians look like real heroes but what about all the unreported crime/violence that happens?
Anyhow, went to remove my ECU on late Sunday night and surprise surprise, my heater core is weeping. Entire passenger foot well is damp, explains the horrific smell in the car.
  • Sad 1
What's your plan with the heater core leak mate?
Looks like dash out/replace :(
This is a street/track car so at very rare times I do drive it here and there (as it's quite streetable, has decent audio/AC, etc.)
Yep, I get that completely mate. Same as my setup. I replaced mine while the dash was out for good measure.
Hit me up if you want me to look up the genuine Nissan part number on FAST for you ;)
Thanks Timmy! But I've already ordered some overnight parts from Queensland lolol
Thanks to @kudos.motorsports and the team there! (Not sure if Andrew even goes here anymore).
In other news some progress on the fuel system. Using both the OEM feed and return and merging it into a 8AN to be used as a return line from the rail. All bulk heads installed too, 2x 8AN for feed/return from rail and 2x 6AN for the supply/flex sensor and pre filter.
Still a shit box but no dodgy shit here, I've seen shops where lines are fed straight through the body work. Dodgy AF.
  • Like 1
  • Thanks 1
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
    • Oh yeah, always always always turn over an engine by hand first.
    • So by that logic, an insanely expensive GTR for $200k+ is quite cheap, at 12% of Sydney's median house price compared to over 50% when a GTR was new...
    • Apologies... thought i had outlined it... Cheers for the response, I'll get a nipple sorted out for this.
