I'm skipping that and going straight to motor/box out, then I'll look at the head and you can come over for some beers and laugh...
I must say, it has survived many many many many track days and numerous anti-lag 2-step launches too (on private property ahem..)
On ‎12‎/‎12‎/‎2016 at 5:35 PM, Dose Pipe Sutututu said:
fuuark that, big cams are gay on a stock motor.. I would go big cams if I had a built motor, solid lifters, cnc ported head, blah blah blah and rev it's mum to 10k rpm witha  sequential box.
But nah.. it's a stocker heap of shit.
Goal: 400kW stock bottom end.
It can still do it! lol
LOLOLOL.. yeah and watch a few rods go through the block when the rest of the Ringlands are smashed and snag on the cylinder walls lololol
See no worries, you'll still have a few rods in there, gotta keep it positive lol
le siet bok updates, pulled off cat (turbo shrapnel filter) tapped out bits of engine and turbo:
then went onto disconnect all the hoses, accessory loom, blah blah blah. Removed the AC compressor, powersteering pump and cabled tied them both out of the way (don't want to regas because tight arse asian). Removed nuts on engine mount. And yes, something had to go wrong.. ended up snapping the coolant hose connector that goes from motor to firewall. Lucky wasn't the heater core hose fittings.
And yeah, managed to take off the bonnet on my own, aesthetics - not really I've gone fat.
So now, as you may have seen in the WTB section, I'm searching for a motor being a neo or just a built rb25det. Let's see how that goes :)
Unfortunately with so much going on, I won't have much of a budget to fry. Just waiting on NST to go up in price and I'll sell my shares to build this turd into a glorified fast turd.
  • Like 3
so yeah, a bit pissed on straya day but the motor came out.. barely... I forgot to remove the shifter LOLOLOL...
We were like wtf.. the motor and box was jammed, looked underneath and "f&%k c&_t, piece of shit c¥×t"... so motor back in ish, then shifter out then round 2 and now we're here!
  • Like 5
Happy Lunar New Year, also treated myself to a new trolley jack because it's red and red is a good colour during the New Lunar Year lolol.. (I have 2x jacks now lol..)
Also took the box off, and yep that's it for now.
On 28/01/2017 at 2:04 PM, V28VX37 said:
Show us the block and pistons Johnny!
soon my friend, the gearbox bolts are too short to mount the engine onto the stand lol.. need to sort that out first!
20 hours ago, Manuel Kasko said:
Engine for sale in VIC
After a built motor in Sydney, but thanks anyway man!
  • Like 1
    • Way more than 1cm. Appreciate the advice maybe I try changing the bushing first
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
