4 hours ago, niZmO_Man said:
Nice whiskey! How does it taste? I never tried Australia, $70 Aldi whiskeys for me
tastes a bit similar to a Hibiki 12 to be honest :)
However, it's hard to beat the Aldi 8 Year old Highland Black. I poured some out to my whisky snob mates and ask them to rate it.
Then I told them what it was and price and they were all mind blown.
On 5/14/2019 at 10:19 AM, ActionDan said:
Only 3yrs? pathetic.
8kg washer for 2 people?
Is this your way of telling us you're expecting twins?
I have a 10KG washer for 2 adults.
Never wanting children.
Have dog and 2 cats instead.
Is freaking awesome when you see the blankets we throw in it :)
also can save a month's worth of washing and do it in one hit :P
  • Haha 2
Update, started to assemble the cabinets. Looking pretty good. Glab the measurements turned out right and I didn't cook it up.
Just need a bigger hole saw to cut the drain pipe into the cabinet and relocate the power again. Initially was going for 3x 400mm cabinets but ended up with this arrangement instead.
Once the cabinets are secure, then I'll get the stone guy/girl to come fit it in, followed by more tiling then fit the top cabinets and I'm done!
I wish I had this kind of motivation with the car lol.
  • Like 1
7 minutes ago, ActionDan said:
Fair enough, whatever makes it more enjoyable for you.
I like flames but...
Dw, it will still launch flames :)
Remember the gate is plumbed back after the cat
    • Thanks Duncan! Yeah it's street use for me only. Maybe occasional track day. Any difference in noise when running with the two pumps? I would expect the lift pump to be more quiet than the main pump so hopefully not? And yes, unfortunately quite a big price difference to the simple hanger setup. Though I'm usually willing to trade money for better reliability and future-proofing. Buy once, cry once and all that. I'd be very happy to never have to deal with fuel pump / wiring issues again
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
