Tier 4 engine bay, will be Tier 3.5 when it gets a new plenum and the cam cover hoses routed properly.
Going to powder coat all the parts soon, when I find someone (when I get off my arse)
  • Like 2
Tier 3 laundry nearly done, just need to adjust the doors, fit door pull tabs, hit it's mum with silicone, fit new taps/spout (whenever it comes) and gap fill and ready for roll racing.
  • Like 2
  • Haha 1
All the pro shops will be blown away by the build quality.
  • Like 1
Is it just the photo or are the panel gaps all f**ked in the two top right doors?
Need to adjust them Habib, wallah hasn't gone to the dyno yet - relaks
  • Haha 2
All the tuning shops will be mad, Nistune is pretty decent.
Your using Nistune for the frontloader?
Does is have enough hektic features, I was sure you would be running a Hellatek plug and play with the systems dash..... hows else you gonna know the RPM of the washer
Bro.. niztoons has laundry control and full flex detergent (3x sections for pre, wash, and post wash), and you can preselect RPM :)
  • Like 2
I want to see how well it goes when you do the cold water to atmosphere purge during summer to make sure you're getting the coldest possible water into that wash!
That spray will look hectiks!
Getting quicker and quicker at doing timing belts lol..
So car was weeping oil from the front main area, I initially thought I over packed the pump with grease and on it's first start up there was an air pocket that popped off the front main seal. Wasn't leaking too much, but enough to start forming droplets near the crank after a drive.
So thought today was the day to remove the lot and pop in a new front main seal, to my surprise it turned out to be lose oil pump bolts ???
Yep, RTV the sump, new oil pump but when I went to tightened up the lot the next day after the RTV dried up, I forgot about the oil pump.
Anyhow, tightened up it's mum, here's hoping it won't weep anymore lololol.
  • Like 1
Reminds me of the time my mate and I both thought the other had done up the front passenger calipers bolts when we'd had them off t paint them on my first 33.... until it came off at 60 and jammed the wheel to a sudden stop....
at least it stopped! lucky!
Real quick, complete with sparks from the wheel well.
As an early 20s NFI home mechanic, bricks were shat lol
Part of why I am so appreciated of SAU and did my own tutorials for it etc, the info I gained here allowed me to be a less shit mechanic.
Edited by ActionDan
  • Like 2
    • Put a hand on an injector and see if that's what the buzzing is. You might be triggering the injectors by moving off idle command.
    • Ah, should have been clearer. Currently has a flex sensor installed all good to go.    like u mentioned, I’ve only ever known the car on e85, I might hate 98, but I have to try it out first. Everyone says the -5 turbos get pretty laggy on 98 octane tho…
    • Duncan , the plan is to get the down pipes done then I book it in for the full tune . Most likely late May , that's the plan.
    • The suspense is killing me lol.  Are you going to buy a flex sensor, then add the 98 tune to your current tune?  It sounds like your just going to delete the current tune and re-tune the car on 98 =/ If you've only known your car on e85, I don't think it will be long before you install the flex sensor and go back to running e85 when its available lol.
    • Currently on an e85 only tune, but I barely get 200km from a full tank. Makes going for longer drives difficult, especially when u leave Melbourne metro as there aren’t many united servos, hence why I’m thinking of going more of a 98 setup.    And yes the smell lol. Any drive afterwards I need to have a shower and wash all the clothes I was wearing, it’s like someone made a Calvin clown e85 perfume and sprayed it all over me haha
