10 hours ago, admS15 said:
Man these low km RB25s are less reliable than a VW motor. Part of me is saying a C63 AMG is more reliable lol
Yeah nah, you need more RB in your life but I won't argue against a C63 either. Do both, lol :)
  • Like 1
Funny you say that, I own a RB25 but mainly tune SR20s lol.
Rebuild plans so far, still indecisive about a few items:
Spool rebuild kit with the CP Pistons, Spool Sump, Camtech 264 mini-brappers, Performance Springs
Now the indecisive items:
Spool spline oil pump gears with an N1 pump, and Spool head drain.
Also my thoughts, if I run the head drain there wouldn't real need to run oil restrictor right? or wrong?
  • Like 1
I was under the impression many people had seen the head "drain" was actually just a sump vent in effect.
I'd do both if I had it all apart, never think about it again.
Yeah I had a good chat to Piggaz about it, looks like I'll run the restrictors still.
Funny it seems people are against running the spline driven pump gears say there isn't enough "movement" for slight crank imperfections and could chew up the pump. sigh.....
Yeah looks like I'll get the Nitto pump, it's only a bee's dick more than the Spool spline billet gears and a N1 Oil Pump housing.
I was trying to make the motor bullet proof, and that means rev limiter abuse proof like 1JZ and 2JZ, but I've read that the poor harmonics of the RB crank itself is enough to cause the crank snout to move and exceed it's normal circular travel cause any form of spline driven pump to misalign and go chomp. "Apparently" through Facebook whispers Nitto did the whole spline drive thing and abandoned it because it worked out more reliable keeping that Nissan oil pump drive style.
  • Like 1
2 minutes ago, ActionDan said:
How that limiter behaves has a bit of an impact too, if only you knew a good tuner.
I do, he is me lol. Like Scarface once said, I trust me lol.
My limiter has a soft cut at 7400rpm followed by a hard cut at 7700rpm with timing pulled before it hits the limiter.
This is an interesting point. You'd think Nissan spent a great deal of effort on engineering something reliable, but I guess something went slightly wrong with the crank. Even after 20 years, Nitto found that sticking with Nissan's final design choice was the 'best'. I guess all those Group C experiences didn't go to waste :P
BTW, what about Reimax gears vs. Nitto pump?
Have done a bit of reading on the spline drives, they seem to be used in the UK a fair bit.
Think someone on here (in the build threads somewhere) is doing a build with the spline, and put up the fitting instructions. I think it mentioned removing the dowels that locate the oil pump to the block, nip up the bolts, rotate the crank a few times (guess to "centre" the splines) then torque bolts to spec.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
