Shit Box Specs:
  • Garrett GTX3576R Gen 2, divided 1.01
  • Tomei 260/9.15mm Poocams
  • Sinco Twinscroll manifold, single gate (pulses split all the way to the gate)
  • Turbosmart Gen V 50mm Gate
  • 3.5" TBE with 5" 100 cell cat, mid muffler and rear muffler
    • Gate plumbed in after cat
  • Built blah blah.
I think the power range I guess will be fine then?
Or should I bump the range to 440rwkw to be safe?
Close to 600rwhp seems about right?
Edited by ActionDan
1 hour ago, Dose Pipe Sutututu said:
Shit Box Specs:
  • Built blah blah.
Are you going to fully send it ? What kind of Dyno?  And fuel system big enough to support full send (thinking 1300cc injectors?)
Edited by Lithium
@LithiumMainline roller dyno, will be using 255 semi slicks too LOL.. don't have any other tyres/wheels to use.
Fuel system will be good :)
  • Bosch 1480cc (aka 1500 or 1550 or 1650cc depending who you talk to)
  • 2x Walbro 460L in surge
  • 1x DW200 in tank (lift)
  • 8AN from surge to rail
  • OEM feed & return as return
Not too sure about full send, however let's see. A bit scared the gearbox will go bang instead lol.
  • Like 1
1 minute ago, admS15 said:
452kw and an exploded gearbox within 2 hours of finished dyno session.
LOL as I was typing the above response about gearbox going ka-blam lol
Just stay out of 3rd gear, she'll be right. Otherwise, i have a brand spanking new in box r34gtt gearbox sitting in my shed that may or may not be for sale. Actually, i better hold onto it.
That should be a very solid setup all around if it all cooperates and you aren't shy.   I'll go with 452kw but more or less wouldn't shock me
@admS15 will need to, will find a pair before the dyno day.
@Lithium kind of pulling my finger out because I have a track day to attend (gift from the S15 owner I tuned recently).
1 minute ago, ActionDan said:
Just saw your fuel system, downgraded power now because using pleb brands.
I know, at least 50kW less now because not ID injectors and mechanical pump.
On 5/30/2020 at 4:13 PM, Dose Pipe Sutututu said:
Why not, celebrate driving the R33? Great excuse to open it.
We are coffee pals. I have the same machine (well actually the cheaper one without an LCD).
Mine has been going strong for 5 years. It's been through three offices and now makes my morning coffee without fail.
Literally the greatest little coffee machine i could have asked for. I trust yours is going just as strong?
  • Like 1
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
