3 hours ago, iruvyouskyrine said:
I think i will end up welding a -3AN line to the dipstick and run the sensor remote. If i had the blank in the block it would be ideal.
Not a bad spot for it! At least it's hidden!
On 23/07/2020 at 10:21 AM, Jasoncauser said:
Yer I just tried the link and works fine, but you may need to be a member of that Outside Skylines group to see it?
They also put this post up the other day which does show some merit :)
But can you believe everything you see on facebook lol
It would be more useful if you knew what other oil control that engine had in place. Is it a case of 30 minutes of drifting, filled catch can, decided to pull engine out and fit sump vents and oil restrictors, or did they just fit those splash plates? By the way it's written, you would hope they have just fit the splash plates and it's a straight back to back. But who knows.
End of the day, it probably all helps. But the big ones are all in the oil control thread, and I don't believe these splash plates are a solution on their own. You don't fix 30 years of inherent oil control problems with some $80 bolt-ons.
Popped my exhaust back on, so much better!
Has a rolled exhaust tip and it's smaller too, no more cut shins!
Ordering more fittings off MSCN next week to vent the crank case into the catch can, hopefully that should "solve" the catch can issue. If not, motor is coming out, I'm going to fit a Nitto oil pump and weld on 2x sump fittings.. because made a bad decision, bought a R33 and now paying for it.
55 minutes ago, Dose Pipe Sutututu said:
@mlr legit feels like it, with the money spent, could have bought a nice M240i or nearly a M2/3/4
As long as it is bringing joy, because if it's not, then stop dropping cash on it and save the dosh for a better toy.
I kinda feel like if you had this M2/3/4, you'd be running into similar issues anyway.
  • Like 1
Bingo, plus none of us know we're going to spend M4 money when we start out lol
In too deep now ?
Hopefully get to race this shit box with confidence after the crank case vent (and better tyres after I destroy this set).
Okay, 2 months later I decided to fit the FMIC, also turns out my old HDi bok choy FMIC was leaking. Explains why boost was hard to control and also why the car always felt a bit flat off boost. That's the blow by oil weeping through the core lol
Anyhow, fitted crank case vent to catch can, also fitted the Plazmaman Pro Series core. Car actually drives better now as it comes onto boost, much more down low and looking at the factory boost gauge I'm getting positive manifold pressure starting at 2700rpm. Big improvement, will go back and dyno it again soon and see what I can achieve with the combo.
(Please ignore those potato hoses from the cam covers to the catch can, all temporary until I go FFP and fit nice fittings and lines)
  • Like 4
19 minutes ago, iruvyouskyrine said:
#nofilter
#badboi
There was actually a massive shop light across the bonnet, made the photos look like IG sex spec
To keep @iruvyouskyrine happy ?
I really need to find a new R33 shell and move everything across. So much rust and shit on this one.
See what comes up @robbo_rb180 right now going to squeeze in a few track days in between finding a new place.
ANZ has royally fked up our plans too, still waiting on our refinance to settle and it's been nearly 3 weeks. Not to mention it took over 2 months for our application to be approved! In too deep now, so yeah.
Stay away from ANZ, bunch of flogs.
Man I need a proper intercooler, you can just see the quality difference. I'm thinking of buying a Hypertune core and making some carbon end tanks, but my wallet is really arguing against it. I feel like I should just give up on ever completing my build this year and buy everything that tickles me ?
  • Haha 1
Sucks to hear about bank drama. Freeing up some dollars for a BMW or more Reno's?
Please do this. How would you bonding to aluminium go with the pressure?
    • Which manifold mate? Meanwhile......Mark is wondering how bonnet vents would look on the NC 🤣
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
