$850 later, ready for garage parking competition.
New seals, new bearings, added 2x shims, backlash reduced a bit.
Just need to redo the ABS wiring, sometime in the past (not during my ownership) someone cut the plug and rejoined it poorly. When I put in the 2 way centre I never bothered to fix it because the mindset was "cheap track car, don't care". Fast forward 7 years or so it's not a very cheap track car anymore ?
  • Like 1
4 hours ago, ActionDan said:
As if not keep it for your next nugget track day special
He's all about Don Mega spec with Samsonas now.
  • Haha 2
11 minutes ago, ActionDan said:
Given the price, you gonna lash out and just go new?
Would be a sensible approach, however when you think about it.. most 350/370Z don't produce very much power. Given that assumption, you would think the boxes are less thrashed than a Skyline box.
Kind of how you would compare a high class escort to a hooker around the bowlos.
1 hour ago, ActionDan said:
I got 2 updates in 2 threads, both posts from you, both posts banging on about Samsonas...
Do you get a commission or what?
I wish :(
On 8/24/2020 at 12:50 PM, Dose Pipe Sutututu said:
Imagine I did, just imagine that!
But reality, this non-Don Mega Ham build will probably just end up with a 350Z CD009 box.
fisch automotive are making RB conversion bellhousings for CD boxes at the moment, im very interested
  • Like 1
Someone should do DQ250/381/500 conversion bellhousing for RB's.
I feel it'll go well with AK47/crackle maps.
Nailed it, I'll take the DQ500 thanks.
If the one in the boat falls out, just pull it out from the missus' Tiguan and I'll be good again.
  • Like 1
    • See my post here If you put the Haltech in, you won't have to worry about any of that. And, in case you're worrying about my lack of credentials in doing your exact swap, I put a Neo in an R32. There has never been a stock boost solenoid near my car and the Neo's ECU has never cared. Nor should it, because it is electronically impossible for it to care.
    • That's 100% wrong. Did you wire in the boost sensor? If you did not, then that is 101% your answer. Neo ECUs do suck a bit.
    • Hello, I'm trying to make this thread basically the thread with all the answers to common questions regarding specifically the RB20 DE NEO + T engine, that comes in the R34. Answers will and only should be provided by those who have done this conversion or actually have some relevant real life experience please. Please feel free to ask questions in the comments if you have any so other members can answer. I feel like this thread is really needed, especially with more Americans buying (unknowingly going to regret it too) rb20 neo r34s. My first question being - What do you guys use for tuning? I have purchased a haltech elite 2500 Plug and play kit for the rb25det NEO because the ecu plug is the same, but I am unsure if any of the pins would need to be repined to match. Second question that I see asked very often - After this conversion, did you install the boost solenoid/ actuator? I see many people doing a + T setup on their rb20 NEOs while running stock RB25DET NEO ECUs with no tune. I am wondering how they are going about doing that and consistently abusing the car because many of these people have had these untuned setups running for a very long time. That was my original plan, but my engine cuts out at 5 psi of boost using the stock ecu with no tune and no boost solenoid/actuator.
    • interesting. ive read and heard otherwise over the past year. ive been doing this +t conversion on a rb20 neo using all oem rb25det neo parts including the ECU, and im having engine cut out issues when I hit around 5 psi of boost. Everywhere/everyone ive asked has told me its because I never wired in a boost solenoid/actuator to the ecu, so the ecu isn't getting the right signal once it hits 5 psi of boost, causing the engine to get shut off.
