What a day, been moving shit to the in-laws, cleaning the house, mowed lawn, planted a bunch of flowers. Then sorted out shit box for tomorrow, bleed brakes, installed new Intima pads (test compound), loaded up car with shit and ready!
Rotors look a bit cooked, I managed to crumble the Intima Type-D v2.0.
@iruvyouskyrine they're 57S :)
  • Like 1
Dose knows I'm good for the $$
I've had to pay him for his services before.... ?
Rotors do look average.
Edited by ActionDan
Motor seized heading back to Sydney. Had full oil pressure, no over heating.
Was tapping a bit on the way home but just thought maybe lifters.
Car did hit the engine protection a few times on the track though for low oil pressure around big bends.
Now waiting for my mate to come back with a trailer on the side of the Hume Highway.
Yay?
  • Sad 7
Cheers @Duncan!
Luckily just at the on ramp to Sydney out of Sutton Forest Maccas, safe-ish spot.
Same tyres lol..
My mate did a 1m10s in it, I managed only 1m12s
well, you can't change the laws of physics; a borrowed car is always quicker than one you own.
at least it is a short walk to heatherbraes (or Maccas if that is your thing)
  • Like 2
I did crack 196 km/h down the main straight but bitches out just as the barrier stopped.
Could have possibly gone 200 km/h+
  • Like 1
Is what it is lol..
Maybe the few times the Haltech went into engine protection was a sign I should not full send it around bends on noise.
19 minutes ago, Dose Pipe Sutututu said:
Is what it is lol..
Do you have logs of the sessions where the engine protection kicked in?
I'll download them sometime during the week and we'll find out.
6 minutes ago, robbo_rb180 said:
That sucks, dry stumped billet rb30det with Samson time?
Hopefully damage isn't to bad and just needs machine work and bearings.
Haha I'm over it man, maybe new car time ?
Get that part out sale going and find a 335i coupe.
  • Like 1
Well shit ?
This is legit the 7th RB I know of thats seized this week. Just as I get my block back from the machinist. Its like the world is screaming at me to stop what I'm doing.
    • Ah right that makes sense.
    • The RPM is just a target, the ECU will adjust things to try and hit that target but it's by no means guaranteed. If the IACV duty cycle is 0 or something like that and it's actually closing up fully then the idle is as low as it can physically go without reducing ignition timing. The problem can be something like the cold start valve in the IACV not closing fully, worn throttle shaft seals, torn rubber diaphragm in the brake booster allowing unmetered air, etc.
    • Apexi, though I'm not comfortable with setting the idle, knowing me I'll f**k it up lol.
    • What ECU is on your car @silviaz? You can just change the idle target table yourself and the IACV duty cycle. Noting that if you play around with the screw you'll also need to revisit the idle base duty table as you will end up offsetting the lot. Another reason why DBW is superior, there's less mucking about.
    • Yep. Saw that on the image above but, wonder if it makes more sense to clean out the iacv because let's say in theory mine is dirty and if I clean it the rpm will drop. If I first go to my tuner to drop the rpm and then go to clean my iacv won't it drop further or is the rpm a fixed number?
