1 hour ago, ActionDan said:
Accumulators don't address the root cause, they just throw oil back in when the issue is most prevalent. They also fail, have seen spun bearings on cars fitted with them. Nothing is fool proof. This is why we have engine protection....
See above.
I agree, I didn't mean get an accumulator and youre sorted - but it is a wonderfully affordable way of giving things a chance, they do work. End of the day, I think its crazy people are willing to drop $1500+ on a billet surge tank and 5 fuel pumps to protect from fuel surge, but not see the value of $500-$1000 to protect from oil surge ?‍♂️
  • Like 4
Certain LS's do have issues with oil starvation, notoriously in long G left handers (like Winton has one of!).
As soon as you go R comp or better (say, slicks in the above example) this is something you just have to be aware of. Gen4 LS's are by far the most notorious for this problem. So much so that GM ship the cars with Drysumps from OEM..
If you go to the track.. really just have to be aware of this no matter what motor you run. Like posted above, feels like an Accumulator on a RB (or any older motor) should be mod #1 before anything power related even begins.
The only motors that seem to be "immune" to it (realistically less prone, not immune) are Renaults and MX5's somehow. Easy to find reports of race series using stock oil control for these motors..
Yet... I want to drive the problem prone one...
  • Like 1
On 15/09/2020 at 4:02 PM, Dose Pipe Sutututu said:
didn't put a hole through the block and through the body work.. no IG likes or won't be all over Snapchat
The reason I like of like the E90/2 M3 more is because it's rare(?) being a V8, it could potentially be a classic in say 10~15 years time.. who knows right?
It's definitely possible. The latter ones are still worth a fair bit but 07-09 got down to around 25k for both manual and dct which is a lot of car for the money.
S65 sounds great but they are finicky and are also torque less wonders ;)
  • Haha 1
Not too sure yet @niZmO_Man been so busy de-cluttering the house getting it ready to get it on the market.
Just picked up stock wheels off my mate and dug out my stock R33 seat.
Heading to out later to swap wheels and seat so the car isn't worth anything, since it's not in a very secure place.
Entire Carrot turbo setup for $50 delivered to COVIDbourne?
  • Haha 1
  • 3 months later...
On 25/10/2018 at 2:00 PM, Dose Pipe Sutututu said:
Nothing too exciting, however got the Nz Wiring Trigger kit working. Turns out the Haltech Elite patch loom is wired to only receive the 120 degree input from the CAS. Took me a while to work that out with Matt from Haltech and Geoff from NZ Wiring.
How did you end up fixing this?
I am thinking about the same kit to use with my elite 2500, was there much needed to get it working?
Turns out Haltech Support was a bit confused and told me to supply +12V to the reluctor and feed it back to the trigger input. Geoff from NZ Wiring actually was right from the start. You don't use the +12v at all, as the reluctor itself generates a voltage.
So all you need to do is use the Trigger PIN & Sensor GND. Both Home signal & +12V are not connected/used.
The arming voltage table given to you by Geoff at NZ Wiring "should" be able to get the car started, however I found that increasing the values a bit reduced the trigger count errors.
I'll get a screenshot of it soon :)
  • Like 1
@Tobz sorry about the delay, laptop was flat lol
Trigger Arming Voltages Below
Trigger Settings, Note the offset is a bit cooked, but it works and even Geoff from NZ Wiring said what I did was ok
  • Like 1
Thanks so much for the tables!  i ordered the kit last night so its in the mail now :)
Also randomly onsong performance released a youtube clip yesterday on the NZ Wiring kit and they reckon all you need to do is re pin 2 wires (i suck at wiring, hate it so much! but he was mentioning something about swapping the cas and cam wires, i need to watch the video again as i didnt quite get it all).  Ill do some research this weekend and im sure it will all make sense.
Depending on your car, you probably don't need to swap anything.
I was running a R34 motor and CAS with R33 wiring. Made things a bit more confusing lol.
If you've ordered the right kit off NZ Wiring it will be pinned correctly to suit the R34 loom. All you need to do is setup the triggering, arming table, then lock your timing, adjust +/- the TDC offset till it is 100% synced.
Then rip skids.
  • Like 1
  • 1 month later...
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
