10 hours ago, Ben C34 said:
I Genuinely am disappointed that the head is going back onto that block........
yeah would be better as a table with a small plaque with the words "A Real RB Head"
What am I missing here? Is the block not clean enough or something?
Or are you suggesting 3L block with 3.4L stroker?
Edited by ActionDan
Not much excitings lately, been busy with house stuff and wedding planning however managed to clean up the block a little. Been contemplating throwing in forged pistons and rods however that's just opening up a new can of worms. The initial plan was to throw in a stocker motor but.... that didn't go to plan lol.
So being sensible I'm only installing new conrod bearings, spool crank collar, spool billet oil pump gears and then balance the crank. Just trying to contact a few machine shops but they seem to be so hard to get to. Might just rock up and drop it off.
Typical RB cranks, a whole 4mm to drive the oil pump LOL.
2 hours ago, R377 said:
With how much boost you run, i thought forged pistons would be a necessity
It's not boost that blows apart motors, it's torque :)
Also being a NEO motor she should be alright with a healthy amount of boost and power. Being a non-GTX style wheel now, I won't be screwing in silly amounts of boost like before.
  • Like 1
  • 3 weeks later...
Lek shu, have been super busy with other shit so le siet bok was put on the back burner. However look what turned up last night? :)
(My mate picked it up for me from HOR thus the not so good portrait photo)
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
