10 hours ago, Kinkstaah said:
You let the Nissan out
Realistically, 300kw. Use it. Enjoy it. Potentially even use it again 😛
I know, and all I did for years was say NEO headstuds dis dat 400kW... hypocrite I am 😂
New goal, reliable 500kW.
  • Like 1
Given we see 1000hp+ turbo LS stuff doing over 400 passes and over 20 thousand road k's , I don't see why not.
At that power I'd call it reliable.
All about how it's built and how it's used.
15 hours ago, BakemonoRicer said:
lol 500KW & reliable......
Go spend 100k and then tell me if you achieve reliability. Pls m8.
No thanks.
Rather go buy another investment property.
All about how its presented on Insta. The breakages get left out when you're trying to sell reliability.
  • Like 3
Paint looks magic mate, good job!  Selenite is a Benz colour from memory? Goddam old car ownership can be frustrating!  Glad you’re giving it some love, hopefully she’s back on the road in no time!
When GT3 racecar manufacturers (Mclaren, Porsche, Acura, Nissan, many other mfg's) all have 500 HP engines lasting 60 hours of use time, or, 12,000km of use (I mean, its track kms though obviously) you know that if they could have made that more reliable... they would have - given they have a massive interest in doing so by having a more reliable motor than their competitors.
And they are not cheap cars, nor cheap engines...
But um... nah mate I have 1000kw for 8 years no breakdowns bruh #bulletproof
  • Like 1
  • Haha 1
Thank you 😁 and yes, it's from a MB lol.. don't hate.
58 minutes ago, robbo_rb180 said:
Since anything Japanese car related is stupid money have you thought of putting the BMW 335 motor and box it?
At least it won't blow oil pumps and smash boxes lolol..
Good news, I've found another block too. Hopefully back on the road soon.
  • Like 1
I found my old neo crank if it's any use to you send me a message, otherwise will put it up for sale. What a reasonable price for a crank in perfect condition came from a running 100,000km engine? Also have full set of pistons (who wants standard pistons though) and rods (same as RB26 so may be worth something,)
Crank is still a short nose crank, same as any other RB25 so not hugely sought after. If its in great condition is doesn't need a grind then maybe ~$200. If its got some gouges or enough where to warrant anything more than a links then the nitriding will be removed and I'd say its pretty worthless, 50 bucks maybe but more likely a bin job.
Pistons for the bin.
Rods, these days probably not so popular anymore, people probably more likely to go with a set of Chinese forgies if they are building a cheap motor. Maybe $150?
Yeh this is the thing - a track car actually uses 500hp. If you have a car that once made 500kw on the dyno, but all you do is drive it 20kms to work everyday at under 3000rpm - you don't have a reliable 500kw car, you have a reliable 120kw car haha. And even then, you will probably still find yourself pulling it down before it ever gets close to 50,000kms.
Nobody is jumping into their 160,000km-since-rebuild 500kw Skyline, driving it to the track and thrashing it for 3 hours, then driving it home. Nobody.
  • Like 4
15 hours ago, Murray_Calavera said:
Has the replacement block been crack tested?
Will be soon, usual checks. If this one is also cracked I will have a sads.
See how I go, hopefully my old crank isn't cactus, if it is I'll message you 😊
And don't worry, I'll send the next motor too. Test and learn, worked out I need more crank vents and even smaller restrictors with an even larger sump. Next motor will last, I'm confident it will.
  • Like 1
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
