40 minutes ago, ActionDan said:
Where can I get one?
https://burubado.com/collections/stickers/products/please-do-not-abusing-of-the-motor-sticker
Could ask for foil sticker, so it's like the one pictured
Lockdown dis dat, anyhow after 3 months of shit just sitting in boxes I decided to do something.
Probably the last time I do something for a while too, my back is sore and my hands are dirty now 😅
Was on the market looking for a used one, wow.. people are wanting like $300 for an used condenser, ended getting a new one for $650.
  • Like 2
14 minutes ago, Unzipped Composites said:
Haha... I threw my condenser in the bin when I stripped the car down, imagining that second hand they were worth 3 cents and a mouldy apple core.
It's covid tax, it has ruined the JDM market.
Long gone are the days of running R33 S2 for $5k to $7k 😔
That's why I chose to go to town and respray and send its mum.
  • Like 1
14 hours ago, r32-25t said:
Where did you get the condenser from?
Amayama, worked out cheaper than local because I bought a bunch of stock seals, gromets, interior bits and bobs.
Vega Motorsports guy has them for GT-Rs at a reasonable price.
Just had a look at r32 ones are almost $1200 😞
  • Sad 1
Can we get thread back on track please.
How are you sydney carnts getting 22c feed in tariff, im in newcastle and did the ring around to every company last year and the very best i was offered was 12c. My solar is about 6 years old now though, are you only getting such a good rate because you got Origin to do a complete solar install?
I can't even imagine getting 50+c a kWh lol
Have a look at AGL, apparently they're doing 20c for the first year!
I'm only getting 22c FIT because I'm going with Origin's Solar system (which is overpriced compared to others, but the only way to get the 22c FIT).
17 minutes ago, ActionDan said:
I just got an email saying I can no longer get 10.2 it's now dropping to 6.7... what the f**k.
Time to go shopping!
Yeah I will, hard in Vic, they all vary so much.
The current mob does a 69c day charge and off peak rates all weekend 😕
In good news, I have found some used Tigo's going cheap :)
  • Like 1
Update, here's a full day's worth of data. Pretty nice sunny day, barely any clouds in the sky.
6.6kW system with 17x 390W JA Solar panels (cheap shit) and a 5kW GoodWe inverter (also cheap shit). Origin didn't really have flexibility with their package choices but after reading into it and also the warranty plus Origin's guarantee of craftsmanship I was sold, especially with the 22c FIT.
We have a North facing double storey house with a colorbond roof. Means theoretically we would get better sunlight coverage.
@PranK what is it with these 250px max width thumbnails? Lol.
1233411653_Screenshot_20210704-222920_SEMSPortal.thumb.jpg.6c4c3765e9769a830d1570eabbffe370.jpg
  • Like 1
would be great if there was a newer nissan you could buy the bits from. i need the whole AC assembly apart from the bit under the dash essentially. im looking at a fortune if i want AC back in my car (which i do)
  • Like 1
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
