On 8/11/2021 at 9:33 AM, Jasoncauser said:
I wish Wakefield and eastern creek were in GTS lol
Bathurst is the only Aussie track int he game
Can get them in Assetta Corsa (via download) on the PC (not console)
I think it was in grid on PS4 they had Sydney Motorsport park
This nearly seems affordable (sorry about the small thumbnail, @PranK still hasn't fixed the image width size)
https://dofreality.com/
On 11/08/2021 at 2:31 PM, Jasoncauser said:
you know thats only the base?
no seat, wheel, pedals etc
Yeah I know - full kit will still be less than me blowing up another motor LOL
  • Like 2
  • Haha 2
  • 3 weeks later...
Making myself a temporary DBW patch harness.
It's nothing pro or club level, just amateur level stuff. Pulled apart Narva 7 core trailer wire and bundled up what I needed.
Still figuring out where I want certain sensors and looms run.
Also, repurposing the old AFM and O2 wiring into an EMAP. For some reason I was under the assumption the power for the AFM is sensor +5V, clearly it isn't so have repinned the narrowband O2 input as a +5V feed for the pressure sensor.
  • Like 1
And done, finished after my son went to bed.
I'm using a V35 Skyline pedal, I did have Z33 350Z one but I didn't like the alloy pedal and wanted a stock looking one.
  • Like 4
Look at you go makin stuff!  Good job! I might go rob the neighbours Triton to war and make my own! 😂
The Asian in me didn't want to pay some auto electrician to make a temporary harness 😂
Future state, will plan out where I want everything to be, and how the cables will be routed and then will pay someone to do the full loom.
FWIW, Narva 7 core trailer wire comes with slightly smaller cable (2.5mm diameter) compared to Narva 5 core trailer wire.
A bit overkill for sensors and a DBW motor still.
  • Like 1
overkill is pretty much always better than under doing it when it comes to wiring!  Are you running the pedal wiring back across under the dash to the ECU and then out through the firewall or are you running some of it straight through the firewall at the pedal to the DBW motor?
  • Like 1
Wiring is going across the firewall (cabin side), then the TB wiring will come out the grommet driver side and then out through that hole where the brake master cylinder is.
I thought about using the throttle cable hole but the DBW TB plug wont fit (unless I de-pin it).
Following Haltech's instructions I ran all sensor power from the pedal & TB back to the ECU side. I've seen some harnesses where sensor power goes from ECU to pedal, then pedal to the TB. I can't see a real issue with that - however better just stick to what Haltech documents to avoid any issues.
Oh hai, I'm sure someone will ask, "why didn't you get I-Beam connecting rods?"
Simply put it, I'm not after 746kW at the wheels. There's 0 desire for it, so these Manly H-Beam connecting rods are perfect for my requirements. Not to mention they came out unscathed from cracking a block in my old motor.
Pretty excited, should be up and running soon enough 😁
  • Like 5
On 01/09/2021 at 7:52 AM, ActionDan said:
So is it not cool if I bought I Beam?
To be fair I have 2 less cylinders to work with so need to work them harder :D
haha yes! simplified calculations puts each of your rods at 125kW, where as for me 83kW :)
    • R12 has not been not available for....decades now. Propane is not a great replacement. (I mean, it's a great replacement, but it is a bit too flammable). R134a being the only way to go forward with an R12 system. The design pressures etc, are close enough to R12's to work. The ability to move heat around is close enough to R12's to work.
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
