RB26 Head questions
Hey guys, I have tried to do some research and I can not seem to find the right threads to answer my questions. I'm currently doing a rebuild on my RB26 head and have a few questions.
My current parts list I have is
Brian Crower single spring & titanium retainers,
Supertech valve guides,
Brian Crower +1MM Intake & +1MM Exhaust valves,
Kelford 280 10.5mm lift cams
And what I can not find is if it's acceptable to reuse the OEM Valve Keepers/Locks and what the OEM Camshaft Studs are rated to. Are these MUST have things when doing the head?
https://www.sau.com.au/forums/topic/468066-rb26-head-questions/
What collets does BC specify/recommend for their valves?  Are OEM compatible?  Check with your supplier.
Camshaft caps are held by bolts.  Any reason they won't work properly?  Are there even studs available?  The items being held only have rotary motion.  Not reciprocating, and there isn't the pressure of combustion trying to dislodge things.
If you establish a plan with your chosen engine builder things can potentially run smoothly as the parts are matched and fit for purpose.  There's been some very good discussion regarding RB26 cams/heads and what can be achieved with surprisingly mild cams combined with the right turbocharger system spec.
I see Tomei does list studs.  The blurb generally indicates they are for fairly extreme lift and rpm eg 12mm lift, 10000rpm.
No real indication of what service this head is being put to.
I stand by comments regarding a discussion with the person chosen to build the thing.  Come up with a total combination fit for purpose.  "Maybe" these things are a useful/necessary item in OP's case.  Doubtful IMO though at a few hundred $$ not much in the overall scheme of a build.
Any particular reason why your going BC valves springs and retainers? For a fraction more you can get a full supertech valvetrain package and dual springs.
Also, whats the intended use for the car as those cams are not ideal for a street car
There's a few machine shops in Canada that have had good luck with Brian Crower springs/ retainers plus there spring specs like coil bind/seat height/spring pressure were closer matched to the Kelford springs that they recommend for there cams. And the stiffest single spring supertech offers is 60lbs which might be to soft. And trying to avoid dual springs and you need to bed the cams in with only 1 spring then add the 2nd spring later.
Cam choice is based off my turbo size and 900whp goal. Its a weekend street/drag car.
Just do the cam cap studs. I did, I just felt it was a bit of insurance and a small cost given what the rest of the engine was worth
Crower are very quick to respond to emails so shoot them off an email about the other stuff. I am sure they will answer in no time at all and give you an answer that will be 100% reliable ;)
    • I'd want an even MORE side on view. More or less you want to make sure the outlet is actually square with the outermost part of the bumper. Or you end up getting soot all over your bumper from your hektik exhaust. In any case, it looks pretty close. I think the way to fix this is probably more of an overhaul at an exhaust specialty shop if you want tips that are rounded off or sit nicely with the bumper but have proper clearance and don't move - Probably more of a redesign than a quick fix. I've pencilled in my own exhaust with its own various problems, pinholes, PITA fitment, and other issues and can see myself going to a shop and saying "JUST DO THIS BUT BETTER?"  Which is gonna work better than any more small fixes. I'm gonna chime in here officially with "from an outsider perspective this exhaust looks fine so this is self OCD probably" (which I also suffer from)
    • Reminds me I really need to install that HKS oil cooler I bought years ago.
    • It be 40°C outside lately. 10W60 is a good idea here. Well, certainly 10W50.
    • Here are some side on's.
    • I just did an oil change on my daily which used oil that is probably 2-3 years old. Normally I try to follow exact viscosities, but my LS400 is fairly tolerant. Dumped something like half a quart of 0W30 Mobil1 ESP X2 in there, followed by 2 quarts Pennzoil 5W30, followed by ~1.2 quarts of liquimoly 5W30 LL04 spec oil. Then the rest was QS euro 5W40 which is actually so thin it's basically a 30 weight oil. All this is to say it doesn't matter that much. We aren't talking about brake fluid. For an RB I would recommend a high ZDDP oil because it doesn't use rollers in the interface between the cam and valve, but a 5W30 or 5W40 is fine to use for street use. The 10W60 guidance really only applies if you're getting it hot and pushing the engine hard.
