Best performance street tyres
5 hours ago, vxsr33 said:
The rs3s also dont make a lot of road noise which is good.
Hardsteppa, i will check out the RSRR next time i need a new set of tyres. Thanks
I'd go a ride in a car with RSR/RSRR before deciding, from all I've read they're cheap and stick well but very noisy. Some have compared the noise to the KU36, which I run, and that's certainly a noisy tyre.
RS3's are meant to have a good balance between price/grip/wear/noise.
i run RSR on the GTR and would never complain about road noise... They have a slight hum but you don't really notice it after a while. And that is even with a relatively quiet exhaust.
  • 1 month later...
it is indeed.
had Rs3's for a few months and yeah they're not bad, but...ad08r's now on all four wheels and wow..I can honestly say, never experienced anything like it. Best tyre I've ever used.
I've had ad08r on my car for a while now. Done a few track days on them and driven daily, they still have 85% + tread and grip the same as when new. Compared to cheap motorsport Street tyres, rsr, 123s etc. These actually last and it will be a long time before you see their performance drop off. Easily the best road tyre I have used that can handle and work well on the track (never used rs3 to compare though). I've recently been using A050 semis for my last 2 track days and have only managed to go 1 second quicker. If I don't end up going at least another sec quicker, I'll be going back to ad08r.
  • Like 1
3 hours ago, -S- said:
Can anyone comment on re71r ? Will these tyres be a waste if used for street only? I think these are on par with the ad08r ?
The new re71r's are amazing.  I was strongly debating mounting a set but a great deal came up that I couldn't pass on.  They are hugely popular in auto cross in the states.  If you drive spiritedly, you would enjoy the extra grip but I doubt you would get anywhere close to their limit on the street.  I haven't even hit the limit on my 003's.  In the end, they're one of the best street tires you're going to find, but to determine if they are worth it to you would be dependent on your driving style.
I initially wanted re003 as i think the re003 would last longer than the re71r... plus maybe the re003 would be better on the wet too compared to the re71r... then again i think the tread wear rating for both are 200 and 210 respectively so not much difference. (I could be wrong) but thanks for the feedback! Might really look into it. ..
If the RE71R is a rave-worthy tyre, then the RE003 is a long way from that.  I put them on my car.  Previously having used AD08Rs and before that various KU36s etc.  The RE003 has nowhere near as much dry grip as the AD08R, so should be at least as far behind the RE71R.  The RE003 is pretty good in the wet, no argument.  The life expectancy looks to be pretty reasonable.  I'm going to get a lot more life out of them than the AD08Rs, which is the main reason I decided to try them.
FWIW, I'd probably use the RE003 again, even with lower grip levels.  They're still a pretty good tyre.
Any of you mix tyres? Different brands and size front and rear. Is it advisable?
I was looking into 255/35 rear and 235/40 front because 255 will not clear the front...
Dumb move?
ok i'm revising my vote. AD08's are great, and hopefully they should last a while, but, RSRR's are the best (grippiest dry, and I also found them fine in the wet)  tyre I've used. Don't last long, but, don't cost that much either.
  • Like 1
Don't slap me around here but I'm running NS2R's by Nankang.
Semi Slicks very good in the dry and in the wet I had traction in 1st my old Bridgestone R002's didn't.
Not saying the best tyre but pretty good so far.
Have 1000km on them but that's first review.
 Share
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
    • @99RS4just wondering if you ever took photos of the footwell lighting / how you bypassed the controller, im keen to haver footwell lighting come on when I open the doors too
