So it's a shitty 20yr old design that was compromised even back then but has a huge price tag just cause fan boys will still buy them
From what I've seen from plasmaman the ARC is a superior intercooler for both flow and cooling efficiency. They are both tube and fin which is great for 400kw and above but the ARC not only has altogether larger charge entry windows, but has smooth funnel shape entry faces around the edges of all its tubes on the charge entry side.
E06B272B-62A2-400B-BC4E-7AC09C20A4EC-1570-00000204D71CB46B.jpg93884D4A-9304-4505-ADE4-A55F4B48E24B-1570-000002052E7E0A34.jpg
compared to the poorly flowing entry of the plazmaman with its (dare I say) outdated 3-4mm protruding tube area in the intake charge end tank area that creates eddies and vortexes around these raised edges making the air do a 180° away from the entry and then another 180° back to the entry again.
36A46848-63C0-473A-965F-2337DA49989C-1570-000001FCD6EC9F42.jpg8B2CC7C2-8D4F-408D-BC5B-7518149B028F-1570-00000205F917FDDC.jpg
The ARC appears to have louvred, serrated and wavy fins in its core which all vary slightly in flow and pressure drop but are all very efficient at absorbing heat and creating chaotic flow which mixes the charge air around in each tube as it passes from hot side to cold side furthering heat absorption efficiency but again at a ever so slightly higher pressure drop. This minute pressure drop would more than likely be offset by the gain in denser cooler charge which in turn will obviously make more power.
The fins inside the ARC also have a larger surface area on their "apex" where they contact the tube wall surface which gives a drastically better chance of all fins being fully fused to the tube wall which in turn guarantees the whole core will do its job absorbing heat and passing it onto the outer tube walls. IMG_3053.jpg
The ARC also has delta fin or apexed ambient side tube faces which are proven to scrub heat more effectively than plain "bull nose" radius tube faces.
The plazmaman core inside looks practically identical to my brothers HDI Gt2 $350 core inside but definitely has better end tanks than the HDI...
The Nismo items are very similar in design to the ARC, so you may find that these apparently "outdated design" coolers might actually be a little ahead of thier time lol
Ok...so that nismo looks like an older model and very similar to the older HKS and trust/GReddy cores I've seen, which are still a great design for big turbo, high kw applications and regardless of the protruding tube into the tank area, are the best flowing and strongest design by far having only three actual components to their construction. The charge air entry windows are larger and less restrictive on these types and additionally, the fully extruded tube/fin type core you see in these HKS, Trust, Nismo type cores fins have 100% cooling efficiency in that the fins are actually part of the tube structure and so are joined to the tube wall 100% everywhere which guarantees all the fins will absorb and disperse heat to the outside of the core.IMG_1925.jpg
The nismo is absolutely overpriced though...If I was spending the big dollars, I would either go hypertune or ARC for sure.
The hypertune runs a euro type core and are clearly excellent quality with a good design charge entry plate area, the apexes would promote flow and the large height of the entry windows would also further this.FullSizeRender.jpg
Plate and fin are more prone to failure though, as they have many more components to their construction which also makes them heavier but even without knowing where their cores come from, one would assume the hypertune is of all round top level quality.
One compromise with the hypertune is the ambient air faces have straight flat fronts being bar and plate FullSizeRender.jpg
which don't cut through incoming air as well as the rounded bull nose face of the tube and fin types which flow better and get more air to that radiator
Or even better again is the ARC with its delta or apex type ambient tube face that cuts air better while getting more cold air scrub across the angled face giving more cooling and great flow all in oneFullSizeRender.jpg
My other and biggest complaint with the hypertune is the charge entry and exit being at the same height and direction on both ends...
the ARC, plazmaman, Nismo, HKS, Trust, HPI and oem types all get the end tanks right with the slightly uneven entry to exit height and tank angle shapeFullSizeRender.jpg
The uneven entry/exit helps mix charge air and fill the whole core more evenly thus preventing a certain percentage of pressure drop and getting a more efficient level of heat soak inside the core resulting in much more cooling.
Like the above brand coolers, the hypertune does have an ok shaped end tank in that it has a straight merge from inlet pipe to core face FullSizeRender.jpgFullSizeRender 2.jpg
This prevents flow eddies that like to form inside corners and promotes faster flow which is a good thing inside the larger 100mm+ and long coolers because by nature, the bigger the core, the bigger the surface area and the bigger the restriction/pressure drop can be.
Intercoolers are like everything in the turbo game, it's all a compromise and about what suits your goals best.
Nismo cooler was purchased May 2011 so it’s not “that old”.
I believe Hypertune were looking into a cast end tank. Not sure if it has happened, I haven’t seen one to date.
The pics of that 33 look familiar ??
  • Like 1
  • Haha 1
I would love to see their cooler with cast end tanks!
IMG_5099.thumb.jpg.2589e590c842759d446ed1b8ef07f839.jpgIMG_5109.thumb.jpg.9b6f0ee5993c05f64cd032a0329691cd.jpg
New Nismo intercooler has different design compared to old one.
Not necessarily, it's still extruded tube design like the old one but the tubes look to be full extruded tube and fin and stacked a lot closer together with less size to the fins in the new version tubes..
It looks like it would flow more and better but possibly at a slight cost to cooling efficiency [emoji848]
Do you actually have any data or just sales brochures and belief on what you think looks like works?
I could say the same about your opinions on the plazmaman and hypertune.. what basis do you have that their cores flow and cool better than any of the high end jap stuff...get over yourself man.
Everything I've stated is unbiased data and knowledge taken directly from a company who's staff have a combined 56 years experience with radiator and intercooler technology....
and guess what, it's an Australian company.
Just because the plazmaman or hypertune cost a shit ton of money and are partly hand assembled, doesn't mean they're any better than the next cooler.
And to answer your question, no. I've never looked at a catalogue for any of the above intercoolers lol it's just basic science dude.
I see many WTAC and circuit cars all running either Plazmaman or Hypertune or PWR.
Haven't seen many with Nismo or GReddy cores, I would base my decisions on that to be honest.
There's been plenty of top level time attack cars around the world running ARC, hypertune, Nismo, plazmaman, Mines etc. cores and a lot of those cars that run whatever brands are sponsored at that level so it's negligible anyways...but seriously, they are all great intercoolers and as I've already said, it really comes down to matching the core to the set up and end goal.
I'm now a lot more unbiased to what brand has the most high profile cars running them or price tag and am trying to base my judgement on the science behind the different core types. It's been quite interesting learning more about it all actually and I have to admit, when I first started researching I assumed the hypertune would be the outright best haha but there really is no "best" intercooler, they all have their own strengths and weaknesses for sure (it's all about compromise) and as I keep saying, for best performance a core should be matched to the rest of the set up just like when choosing a turbo.
There certainly is a "worst" intercooler tho and that's the poorly made, very low quality controlled materials and construction process of the Chinese types and even some oem type cores.
I would love nothing more than to see some same day, same car, same set up, same dyno data results of all the high end brands from around the world. That would be porn!
So the consensus is?
Probably a moot point for me as I have bought a Plazmaman and my power goals aren't going to wow anyone reading this.
But what I take away from this is:
1. (Newer) Arc and Nismo aren't anywhere near as rubbish as previously suggested but you need a bag of cash.
2. Hypertune is really good but also flawed and you need to wait 6 months to get one.
3. Plazmaman is a good local option that also has shortcomings.
All intercoolers have some sort of "shortcomings" but it's about finding the right balance of flow and cooling efficiency for your desired set up.
I think bang for buck and the fact that the plazmaman being probably the cheapest option of all the high end brands...you've made the rite choice.
I'm surprised how shit the inside of that PWR looks.... the tubes are protruding into the end tank a good 6+mm and weld dags everywhere....welded plate end tanks certainly are a step down in flow from a cast end tank...
The plazmaman easily takes the win out of those three!
Yeah PWR aren't known for their good welds, but their radiators beast (well the cores are). My PWR radiator welds look pretty shit too, when you compare it to anything that comes out of Plazmaman or Hypertune.
  • Like 1
I have to agree with the PWR welds!! My brothers RX7 has a PWR radiator and oil cooler setup and radiator cracks around the welds, it’s been repaired numerous times now . Apparently very common issue with their radiators. Pretty disappointing for like an $800 radiator.
On another note on my Gtr I run a Cooling Pro 100mm Intercooler. Wonder how much that’s restricting my setup. On the dyno after maybe 8 pulls it’ll drop 8-10rwkw but I gotta say the dyno fan was shithouse too
    • It's the adhesive holding the ceramic wheel to the shaft the fails on 90% of them.
    • Foreign debris, physical shock, boost leak, could be anything honestly. The danger in taking all the timing out of a tune/hitting the R&R corner is that even if the engine doesn't detonate your turbo is taking a lot of abuse from high EGT. Also, even if nothing goes wrong it is a journal bearing that is spinning at 100k RPM on boost. Eventually it goes through enough cold start/pressure cycles to wear it out.
    • I kinda accidentally saw this, and was interested, but It actually seems to replaces the whole center computer, using the existing screen and buttons. AND it may only be for a G37 and not compatible with a Japanese 370. So its not for me, but someone else may be interested to look into it. Its about $680USD. If I am understanding it right, it basically replaces/installs and android pc that integrates with the existing screen. But I could be wrong. https://gromaudio.com/vline/ The video I first saw was the following, with very little and unclear details.     Even if your not interested in the system, the video on their site was pretty comforting in showing how simple the whole centre comes out
    • hfygrte52 what side you looking for? Do you care what color car it's off? Found a white LH side on here: https://skylinespares.com.au/product/nissan-skyline-r33-coupe-rear-tail-light/   Aussie parts place but will ship to USA. Maybe get it before there's a tarrif on 25yo shit box parts
    • I’m with Shannon’s for all 5 of our cars. Agreed values seem fair, premium price is okay. ($210 ish a month, all comprehensive).  Have claimed once with them for a not at fault claim with another car where my car had no damage. Was one call after the incident and an email after. Deemed not at fault so premium didn’t go up either.    I have called up and spoken with people who are not familiar with certain cars and didn’t agree with me on value or let their personal vehicle preferences effect the call. But called back later and got someone else who was more agreeable.
