Full Floating Brake Rotors
For custom made brakes there is an option to get full floating rotors rather than the usual solidly bolted together two piece jobs, dedicated race car. Has anyone experience with this type, good, bad? Worth getting?
Not directly related. but a full floating front rotor on my motocross bike made a big difference.
Pad knock back is not a major issue on a dirt bike(we have proper floating calipers as well). but the front brake is more consistent and the bite point is always in the same spot now and if the same rotor is good enough for Toby Price to win Dakar with then it is way too good for me
Fully floating rotors are self centering so are less affected by any hub runout, have less drag (probably more of a factor on a bike than a car) and allegedly have cooling benefits ...not speaking from experience .. I bought D2s...-
FWIW most of the 'real' race cars I've seen photos of appear to run fully floating discs, plus pretty much all the modern European exotics and other supercars. From what I've read they're meant to be better for your hubs due to reduced heat, for one thing.
Depends on how serious a race car it is I suppose, and what the price difference is all other things being equal?
I mate of mine runs a front pair in his relatively stock Evo 10, reckons it is an improvement.
Wondering if pad knock back might be a problem, the extra rotor clearance they make would have that effect but if it's noticeable at the brake pedal is another question. Might ask if full floating can be converted back to solid mounted, the difference looks to be some fancy attachment hardware so that may be possible if knock back is a problem.
Certainly have read all the responses, they are all helpful but I'm trying to get my head around a better pad clearance feature that does not involve knock back. Not saying that it does, I just don't understand how that is possible.
Stop tech make a set where you can reverse the bits that attach the rotor to the centre to have optional full floating.
wow. he clearly knows his shit and there is good info in there....but did no-one watch the video before posting and suggest it could have been made clearer?
anyway....I'm not saying there is no benefit to something I've never tried, but in 10+ years racing the skyline up to 1 hr enduros I've never had pad knock off, nor have I had a wheel bearing fail. Maybe the z is different to the skyline setup though.  I've had plenty of brake problems over the years with boiled fluids, over temp pads, race pads not working on the street, master cylinder leaking etc etc, but never pad knock off.  I suspect the skylines just have nice big wheel bearings....not that I ever had the problem in the evo (6hrs) or daewoos (1hr) either
Duncan....an observation  is that it only is an issue from time to time on setups over 355mm. i think up to that  size you are fine and rarely have an issue.
I have seen and know of  some cars running 380mm rotors etc that have knock off as due to diam any hub deflection ends up with more movement at the rotors outer edge
  • Like 1
OK understand it now, thanks all, Roy's point about large diameter rotors makes sense too. So for a limited use race car the only disadvantage seems to be extra $ which seems somehow to be a familiar theme.
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
