Full Floating Brake Rotors
For custom made brakes there is an option to get full floating rotors rather than the usual solidly bolted together two piece jobs, dedicated race car. Has anyone experience with this type, good, bad? Worth getting?
https://www.sau.com.au/forums/topic/468094-full-floating-brake-rotors/
Not directly related. but a full floating front rotor on my motocross bike made a big difference.
Pad knock back is not a major issue on a dirt bike(we have proper floating calipers as well). but the front brake is more consistent and the bite point is always in the same spot now and if the same rotor is good enough for Toby Price to win Dakar with then it is way too good for me
Fully floating rotors are self centering so are less affected by any hub runout, have less drag (probably more of a factor on a bike than a car) and allegedly have cooling benefits ...not speaking from experience .. I bought D2s...-
FWIW most of the 'real' race cars I've seen photos of appear to run fully floating discs, plus pretty much all the modern European exotics and other supercars. From what I've read they're meant to be better for your hubs due to reduced heat, for one thing.
Depends on how serious a race car it is I suppose, and what the price difference is all other things being equal?
I mate of mine runs a front pair in his relatively stock Evo 10, reckons it is an improvement.
Wondering if pad knock back might be a problem, the extra rotor clearance they make would have that effect but if it's noticeable at the brake pedal is another question. Might ask if full floating can be converted back to solid mounted, the difference looks to be some fancy attachment hardware so that may be possible if knock back is a problem.
Certainly have read all the responses, they are all helpful but I'm trying to get my head around a better pad clearance feature that does not involve knock back. Not saying that it does, I just don't understand how that is possible.
Stop tech make a set where you can reverse the bits that attach the rotor to the centre to have optional full floating.
wow. he clearly knows his shit and there is good info in there....but did no-one watch the video before posting and suggest it could have been made clearer?
anyway....I'm not saying there is no benefit to something I've never tried, but in 10+ years racing the skyline up to 1 hr enduros I've never had pad knock off, nor have I had a wheel bearing fail. Maybe the z is different to the skyline setup though.  I've had plenty of brake problems over the years with boiled fluids, over temp pads, race pads not working on the street, master cylinder leaking etc etc, but never pad knock off.  I suspect the skylines just have nice big wheel bearings....not that I ever had the problem in the evo (6hrs) or daewoos (1hr) either
Duncan....an observation  is that it only is an issue from time to time on setups over 355mm. i think up to that  size you are fine and rarely have an issue.
I have seen and know of  some cars running 380mm rotors etc that have knock off as due to diam any hub deflection ends up with more movement at the rotors outer edge
  • Like 1
OK understand it now, thanks all, Roy's point about large diameter rotors makes sense too. So for a limited use race car the only disadvantage seems to be extra $ which seems somehow to be a familiar theme.
    • Hey all, not sure how active SAU is anymore but will ask away anyways. Just wanted to get some experience on the 2008 model GTR CBA model.  I've hit that age in my life (43) where I'm like fk it time to get my dream (midlife crisis) car. Looking at importing one in and seeing if these can be reliable if the main flaws are fixed up. Plan is to keep money aside to do the following straight off the bat to future proof it: * install a stage 1 rebuilt trans with all new bits and pieces.  * install a new Bellhousing from the later model GTRs. Or potentially an upgraded stronger version like MAD or ATR. Besides the above two things and typical maintenance items anything else you'd recommend doing.   Been speaking to a few people and the engine on these are very reliable apparently. But keen on the view of the community here. Hoping to find a nice grade 4.5 with low mileage in Grey. I'd go black but swirls too easy. Look forward to your responses and feedback. Cheers
    • Do Alan and Keith work on Skylines now? I remember buying stuff from them when I owned my Ralliart Lancer a few moons ago. Definitely genuine guys and be excellent if they dealt with the skyline platform as well.
    • Hey all, I'm Gaston from Sydney's West.  I was a member on here when I was a younger lad and owned a mint R33 GTS-T. Ended up selling it and getting married having kids (yadda yadda) we all know how the story goes. Now I'm back with the intention to get my midlife crisis (dream) car ... a R35 GTR.  You'll see me about asking questions and searching the forums. Good to be back and can't wait to get back an Import again.
    • I have to put something here in order to post the photos. From what I could gather there's more enthusiasm for modified cars now than there has been for years. There were probably more younger people there than older (me included lol) which was a good sign.  It did seem like the record least amount of representation of the 90's era hero cars on display though. Like maybe one or two examples of S-chassis Nissans, and maybe 3 or 4 R-chassis. By comparison there were a lot of Civics from that era but in all there were about 10 - 12 EG/EK Civic Type R.  Euro exotics are always there in large numbers, led by Liberty Walk...... say what you will about kids using markers to scribble on a Ferrari F40, it did seem like a stunt to infuriate Ferrari enthusiasts, or Ferrari itself. I wonder if there's something more to it. Either way LBWK have done some heinous things to a Lamborghini Miura this time. They should stop now.
    • Engines and drivelines are not war stoppers for me mate, busted arse bodies and un-obtainium parts and panels are though Both cheap Brumbies I looked at had trashed tubs and a fair bit of rust
