Fat American
Hey everyone. My name is Fred. I'm from St. Louis Missouri in the states. 30 years old now. Been into 240s and rb's since highschool. I have a s13 coupe w a rb25 s1. The motors out right now. I pulled it to do the clutch and flywheel then decided to helicoil all 12 exhaust studs since they were all trashed. Then I decided to order a hypergear atr43g3sat turbo, 550 injectors, and a few other things. Don't know how long the motor will last with about an extra 100hp but we'll see I guess. Lol. This page has already been a great source of knowledge so I figured I would make an intro thread. Here's some pics. Thanks for all your knowledge!
  • Like 3
https://www.sau.com.au/forums/topic/468116-fat-american/
    • Anything above ~9.5V is acceptable. The higher the better, but it will almost always drop to at least 10.5V, if not lower, even with a new big battery and everything else being good. 9.76 is not a concern. If it goes below 9, you'd be sure that there's a problem with either the battery or the connections.
    • It's new almost. Under a year old i think and I've tested it twice at supercheap
    • Glue the head from a Pez dispenser on it. Goofy, or Winnie the Pooh, so something.
    • Adjusting the idle screw is usually (emphasis on usually) just covering up deeper issues. Stuff like the cold start valve not closing properly. Throttle shaft seals on the way out. Coolant temp sensors getting out of spec. Coolant temp sensors especially can be a bear to diagnose because they can fail subtly. My dad just spent weeks chasing down his high idle. He cleaned the coolant temp sensor and everything but the resistance curve just drifts over time and if it's been 20+ years they also get super slow to respond as well. Has a massive effect on fuel economy as if it's off the ECU is going to run richer and command high idle for far longer than it should otherwise.
    • How old is the battery, it's more likely your battery is on its way out.
