thats alright, ill take that on the chin.
but there is a big difference between expensive and overpriced.
on topic, get a series 2.
:) Well said aybee. :)
So apart from obvious cosmetic difference between the series 1 and 2 (body kit, interior, ECU) was there any faults with the series I over the series II?
The car MISTIQUE is in fact enquiring about is (apparently) a 1995 series 1.5.
So is it worth while spending a little more and looking around for a series II, or are they much the same?
Cheers.
Ok the only problem i can say with every R33 is water getting in the rear lights :) I cant get it out :)
Hey K, yeah,
I had the same problem with my 95T with water in the rear right lamp. ended up just pulling the thing completely off the car, re-sealing it with non-acidic silicon (can be cut-out in you next accident), then re-applying while semi dry. Also, running a small bead of silicon around the upper seal (while the lamps is installed) also completely keeps water out. (don't worry about using silicon, as it does less damage to your car than allowing water to 'come in and stay). I bet that on warmer days, the water 'condenses' and appears on your rear windscreen???????
It eventually kills everything in your boot!!!
As for series2 Sklines'....I much prefer the very last series 1's. Their front bumper looks more aggressive (as opposed to the odd looking round indicators of s2). The last S1 has most of the s2 stuff, just cheaper and better looking front...mmmmmm...very subjective thought :Oops: !!!
Anyways.......
SuperSpitMark.
Cheers.
The main "fault" with the series 1 was the ECU, which tends to run way too rich when upping the boost. You can easily fix this with an S-AFC, and bring it up to the same power levels as the later ECU. The 95 series 1.5 uses the updated ECU and so doesn't have this problem.
The only other minor fault I can think of is the dash surround and door handle surround is coated in this thin rubber type stuff, which tends to peel fairly easily. This was fixed with the series 2 (not 1.5). But that's really minor.
These cars aren't like Commodores and Falcons which get released with a whole BUNCH of problems, and then they fix half of them with the series 2, and then change models and start off with a whole new bigger batch of problems. This is the reason why I think the VS series 2 Commodore is a less buggy car than a VT series 1.
Hey K, yeah,
Anyways.......
SuperSpitMark.
Thx for that, its my Rear Right one too :)
Fuel consumption will feel bad especially when you jumped from a previous 4-cyl common shopping carts. Heck even my bro complaint about fuel consumption after he replaced his 95 Civic sedan with the new Accord Euro - and his 4-cyl Accord Euro consumption is still LESS than my car!
thats ironic, cause pretty much the only reason i dont like the S1 is cause of the front bar. i think its even got to the stage where i see a stock S1 and cringe at the sight of its front end.
as for the wings, i dont really mind the S1 wing cause its more subtle.
    • 100% accurate!  We are a pack of know it alls....  But, I bet people go to you when they have a problem! I've been on a bit of a clean up rampage too over the past month!  I've thrown more shit in the bin over the past 2 weeks than I have in the past 3 years combined! Anyway, it's all good fun being different! My wife sometimes does not agree!
    • ADHD in all form isn't about "can focus, or can't focus" or is hyper active or isn't etc.   It's all a dysregulation. Either time feels to be stationary, or time just vanishes in a split second. We are either under focussed on the task at hand (as we're over focussed on our surroundings) or we have no idea an atomic bomb went off beside us as we're so hyper focussed and locked in on things.   Not to mention the rapid fire thought process. What it takes a "normal" process to think up a solution to a problem, ADHD will be able to give you 5 different ways to solve the problem, and the pros and cons of each. While we can be highly impulsive and lack the ability to "control ourselves" we can also become paralysed with the inability to make a decision for ourselves. While most of us have an OCD like requirement for perfection, we lack the ability often to remain focussed to get things to a perfect state. Those with undiagnosed ADHD as adults, can often find the last part actually stops them ever attempting to do things that they have the ability to do, as the reasoning is often "if I can't do it perfectly, it's not worth doing"   As for projects... Ha ha ha, I still need to take the other half of my wall trim down in the Fiance's office so I can paint it. Need to finish digging and running the back yard drains, my R33, getting the Ninja bike registered (now being sold), the moped project, fixing either of the lawn mowers so they're reliable, along with a myriad of other things.   It's why I've been going through lately and just being brutal and clearing projects off that I won't actually ever complete. IE, moped will go to the tip, or be given away, bike is being sold, Subaru project being sold, some parts for other projects given away. Or I've been making myself focus on one thing at a time, by ticking off the smallest quickest ones first.   There's also a reason by our mid twenties we seem to be "know it alls", as we've all been down some of the weirdest and oddest rabbit holes when you follow the dopamine trail. It's often also why we're more a jack of all trades, but not a master of one.   However, pretty much all of my hobby projects, in one way or another, all come back around to automotive. That's my zen area.
    • Remember reading about this not too long ago. been for sale for a long time  this is like when the wife says you need to sell the car so you put it up for a ridiculous price no one will pay
    • You are perhaps suggesting that it is not a super car? Well....it's not an AU.
    • Dropped the MX5 of this morning to get the hardtop colour matched and some PDR done, they are also going to give it a buff to remove some "stubborn" swirl marks and light scratches in the clear coat Over the last few months the poor little thing has copped some shopping centre car park abuse, I try to not park in them, but hitting Westfield's a few times over the last few months has taken its toll, nothing really bad, but enough of a trigger for a "while we're in there" thingie  Once it's back and all the one colour, with a few dents and mark's removed I'll give some of these products a go and see what they're like
