thats alright, ill take that on the chin.
but there is a big difference between expensive and overpriced.
on topic, get a series 2.
:) Well said aybee. :)
So apart from obvious cosmetic difference between the series 1 and 2 (body kit, interior, ECU) was there any faults with the series I over the series II?
The car MISTIQUE is in fact enquiring about is (apparently) a 1995 series 1.5.
So is it worth while spending a little more and looking around for a series II, or are they much the same?
Cheers.
Ok the only problem i can say with every R33 is water getting in the rear lights :) I cant get it out :)
Hey K, yeah,
I had the same problem with my 95T with water in the rear right lamp. ended up just pulling the thing completely off the car, re-sealing it with non-acidic silicon (can be cut-out in you next accident), then re-applying while semi dry. Also, running a small bead of silicon around the upper seal (while the lamps is installed) also completely keeps water out. (don't worry about using silicon, as it does less damage to your car than allowing water to 'come in and stay). I bet that on warmer days, the water 'condenses' and appears on your rear windscreen???????
It eventually kills everything in your boot!!!
As for series2 Sklines'....I much prefer the very last series 1's. Their front bumper looks more aggressive (as opposed to the odd looking round indicators of s2). The last S1 has most of the s2 stuff, just cheaper and better looking front...mmmmmm...very subjective thought :Oops: !!!
Anyways.......
SuperSpitMark.
Cheers.
The main "fault" with the series 1 was the ECU, which tends to run way too rich when upping the boost. You can easily fix this with an S-AFC, and bring it up to the same power levels as the later ECU. The 95 series 1.5 uses the updated ECU and so doesn't have this problem.
The only other minor fault I can think of is the dash surround and door handle surround is coated in this thin rubber type stuff, which tends to peel fairly easily. This was fixed with the series 2 (not 1.5). But that's really minor.
These cars aren't like Commodores and Falcons which get released with a whole BUNCH of problems, and then they fix half of them with the series 2, and then change models and start off with a whole new bigger batch of problems. This is the reason why I think the VS series 2 Commodore is a less buggy car than a VT series 1.
Hey K, yeah,
Anyways.......
SuperSpitMark.
Thx for that, its my Rear Right one too :)
Fuel consumption will feel bad especially when you jumped from a previous 4-cyl common shopping carts. Heck even my bro complaint about fuel consumption after he replaced his 95 Civic sedan with the new Accord Euro - and his 4-cyl Accord Euro consumption is still LESS than my car!
thats ironic, cause pretty much the only reason i dont like the S1 is cause of the front bar. i think its even got to the stage where i see a stock S1 and cringe at the sight of its front end.
as for the wings, i dont really mind the S1 wing cause its more subtle.
    • Great work! Give it a clean up with some Emery paper, and I'd run a thread die over the threads too to clean them up. It will make reinstall much easier, and also life easier for the next time it needs to come out.
    • I'm not a fan of high humidity, it's one reason I don't mind being further inland out Ipswich, except the last 3 odd years, the drought broke, and it won't stop raining, which is making the humidity nearly unbearable when the rains are in during summer! For me, my body hates the cold, once the cold sets into my body, I'm totally screwed. I end up with severe muscle spasm in my back/shoulder muscles, and it feels like someone is trying to tear the muscles out. I have no issues with it getting stupid hot, so long as the humidity goes away. So the last 3 years as above, have been woeful! Ha ha. However, June 1st, and I'm only just converting from shorts and a tee, to long pants and a t shirt. And that's mainly as it's a bit wet and miserable and I wanted to work on a car.
    • I much prefer colder weather to hot weather, and especially prefer cold to hot and humid, Goulburn does gets pretty warm in the hotter months, but, I've found the humidity there is not as painful as even Sydney, the humidity up north is to oppressing for this old rooster  In saying this, it does get rather "nippy" in Goulburn for early morning, late in the evening walks, but nothing that a layer or two, some thermal gloves, and a beanie doesn't fix to make it an enjoyable experience, which is much more bearable to me than the oppression of heat and humidity,  especially at night when your trying to sleep If I recall correctly, a "wise man" once said that the "Southern Tablelands" was gods country, and I will not argue that point with him for the fear of a "permaban" LOL In car part related news: My intake is currently in Botany getting processed for the last leg of its shipping journey to my door
    • Had a go at the stuck crush tube this afternoon. Tried things like grips and a chain wrench first but wouldn't just twist straight off. So got to work with a drill. Started small and kept a depth stop on to make sure I didn't drill into the bolt. Made a line of drill holes all the way up and enlarged them. Then a combination of chisel and Dremel to split it all the way up. Levered the split to get oil in there and eventually it gave a bit while levering. Worked it back and forth with loads more oil till it was spinning freely, then with grips I could work it downwards and off. And no significant damage to the bolt (not by me anyway - just the 27 years of rust)
    • Well, I'm tired. I'm tired because about 4PM yesterday, before today's appointment someone immediately bought my bumper. They couldn't get it any other day as they're on the way back to NSW. So I had to do that big GTR conversion I had been planning. Unfortunately, the information on SAU about what you need and how this is done is incomplete. So what should be a simple bolt on affair, yeah, it's not. Did you know if you use all GTR items the bonnet won't close? This little manuever sent me into about 1am the night before trying to dodge a way to get it closed. I will have to revisit this in the next few days  - or maybe not, I may let a body shop figure it out. It all needs to come up and my motivation to pull the bumper off is low. It also seems to hit things in the bay where the GTT bonnet didn't. Yes I used 100% new OEM GTR items. Today, I had the joy of driving to the dyno looking like this: Given I had roughed in the fuel and given sensible but pretty conservative timing, I didn't really bet on having the car drive out any real difference than when it drove in. Sadly due to a miscommunication and laptop fun and games (and almost bricking the dongle, prayers and firmware updates indeed), I ended up using HP Tuner credits to licence the car that was already licenced. So in the end my laptop was used. It turns out my butt dyno is still well calibrated after all this time. The 325kw was on 74% Ethanol, the 313kw line was on 98. The other line is the 'before' line which was 281kw. While the numbers are pretty low, they're pretty in line with what you'd expect. Even if US dynos bump the whole result up about 50KW, gaining 10-15% is similar gains.  The curve of the cam is pretty much spot on with what was discussed as well. All this said, it still feels bad to not see the number you secretly want to see. Even if the car drove great beforehand, and I knew pretty confidently the car would drive out much the same way it drove in due to the nature of a wellish dialled in LS1 not gaining much if anything at all from being tuned from where it was. As expected, the car isn't particularly sensitive to running it at anywhere between 12.0 and 13.0 - And the initial timing at 20deg and 12.0 made 308KW. So 3 degrees of timing, and leaning it out to 12.7 for 5kw, anything above stopped giving any benefit until E85 (which has an additional 2 deg as before). Car itself behaved entirely fine. I found out that 100C = 1.15V! IAT at about 7pm was 19C. I might mess with the bonnet mounting.. but given the REO NEEDS TO BE CHOPPED TO FIT A GTR BAR this is possibly something I may leave gathering (more) dust until it returns to paint jail.
