Yes that's what i thought and hope too. .. just to add , gtst calipers are going in so I'm thinking i should be safe as i read on another forum the NA has a banjo type fitting to be attached to the NA calipers ? Maybe that could be the reason why compatibility is only for the gtst because of the calipers... Well i hope it'll fit...
I'll reply here rather than PM, so the (my) answer is findable by others later, assuming it's correct of course.
I would say that the chances that the "car" side of the brake lines would be better than 99.9% sure to be identical, regardless of whether it was an NA, a turbo, a 2dr or a sedan.  Both chassis (2dr and 4dr) came as both turbo and NA, with the brakes appropriate to the engine.  So I wouldn't worry about that.
If you're putting turbo brakes onto an NA car, then yes, absolutely, the only sensible thing to do is use the turbo flexible lines.  They will definitely match the caliper, where the lines for the NA brakes will almost certainly not match the caliper.
Edited by GTSBoy
  • 2 months later...
umm yeah, they were probably removed with the brake lines.  they are short hard lines with male fittings at both ends which would allow the female at the caliper and the female at the braided line to mate up
  • Like 1
you'd be better off with a conversion package to the 324mm gtr discs. If only you were in contact with someone that has those discs, the GK Tech caliper adapters, the calipers machined to suit, and with GK Tech braided lines, all for sale as a package.....rather than a2m'ing around with stock brakes.
oh wait...I have that :P
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
    • To clarify what I posted above, I thought you both had a situation where it cancelled sooner one way than the other.....if it is reasonably even where it cancels in either direction that is probably normal (consider gentle movements like lane changes, you don't want it to need half a turn of lock to turn the indicators off)
    • Son, in this country, that is a piece of Gyprock. f**king drywall. FFS! I also like the autocorrect of trailer to tablet. I was reading it and thing, "what the hell drugs is he on?" Then the photo made it clear enough.
