peter Kent
G/DAY ALL my name is Peter as you can see by my tag I'm a newby to this site, I joined as I'm having problems with my 1997 N15 1.6 daily driver,It jumps out of 5th gear under load  I've replaced all the engine mounts  and this has not fixed it as I'm not familiar with these cars I'm hoping someone here can give me some advise .
Cheers Peter.
https://www.sau.com.au/forums/topic/468176-peter-kent/
    • Car should sit at 12.2 or more, maybe 12.6 or 12.7 when fully charged and happy. If there is a decent enough parasitic load then it will certainly go lower than 12.2 with time. You can't beat physics.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue. Isn't 12v low, shouldn't it be around 12.5v?
    • Anything above ~9.5V is acceptable. The higher the better, but it will almost always drop to at least 10.5V, if not lower, even with a new big battery and everything else being good. 9.76 is not a concern. If it goes below 9, you'd be sure that there's a problem with either the battery or the connections.
    • It's new almost. Under a year old i think and I've tested it twice at supercheap
    • Glue the head from a Pez dispenser on it. Goofy, or Winnie the Pooh, so something.
