product review - adjustable rear lower control arms
I'd  been looking at the no-name chinese made adjustable lower control arms for the R33 gtst (ikeya ripoffs by the look of it) and haven't seen a lot of info out there about these so, when I saw a set fairly cheap through Tas Autosport (Great seller, Hamish is great to deal with and very well priced) I grabbed a set to see what they're like.
First thought was, Christ they're heavy but weighing them up they came in just on 3kg and the stock arms were 2.54kg so not THAT much heavier, and they're wayyyyy more solid. The finish was good, welds look decent enough. Outer end looks to be a forged piece? Inner bearings have a rubber cover but outer ones (spherical bearing rather than ball joint) don't, although neither do the top-brand ones that I could see. These will be on a road car so grabbed a set of rubber boots from repco to fit over them rather than leaving them exposed.
Fitting them to the car, the inner bearings are too short (around 5mm) to fit snugly inside the subframe mounts so you will need a few washers to put at each end to make up the distance. Not a big deal but make sure you have some handy when fitting. Otherwise they fitted just fine, and the swaybar mounts are in a better position if you're using an adjustable swaybar as I am, with the stock arm mounting points not quite lining up properly.
Will update after doing some real driving on them but initial thoughts after a quick drive; as you'd expect from such a solid piece compared to stock there's a real firm and direct feel when weight's transferred to the wheel when cornering...although I've found words don't really cover the feel of the car, it is just that, a feel you have to drive it to appreciate.
These were $220ish delivered, and on the stock arms I'd replaced the ball joint and fitted superpro inner bushes so would have been close to this price already. I'm assuming the weak point of these will be the bearings (outer ones are easily replaceable, held in with a c-clip) so will see how they go over time and after some more extensive driving.
The open design also makes it a lot easier to work on (refitting swaybar links were a breeze).
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
