Blueprinted RB28 Neo
I don't expect to sell this, especially not quickly, but here we go, it's up for sale, and I await burny flames, because "Greg Car™"
What I have is a fully blueprinted, literally built yesterday RB28/29 RB25DET Neo with juicy VCT, unlike you dirty RB26 people. It's also in a car, running, and available for any test you would like to do. In fact, I'd encourage it. The blueprints are obviously included with the same and to have a look at beforehand and all that.
The pertinent info:
Compression is 9.01:1
It has a Brian Crower stroker kit from the USA in it (http://www.briancrower.com/view.php?pn=BC0238)
86.5mm pistons that were custom made by JE and Nitto to fit the Neo head (the kit was for RB25DET and RB26)
I say JE and Nitto as they are actually badged with both brand names.
JUN Oil pump
Lewis Engines baffled/gated and extended sump.
R34 has 1.27mm restrictor in it standard, one feed has been blocked off. The oil returns in the head and the
block have been enlarged.
ARP2000 Head Studs
ARP Main Studs
ACL Race Bearings
Tomei Metal HG, 1.2mm.
Tomei Type B 260deg Cams
Tomei Exhaust Cam Gear which does nothing but is installed..
Supertech Valve Springs
The head was ported and polished and unlike most ports and polish actually helped performance a pretty big
amount. And by "helped performance" I mean along the lines of the same power at about 10psi less boost.
Being built yesterday, it has a full OEM Nissan Gasket set for everything minus the HG, and new belts.
If it's so amazing, why do I want to sell it? I only aim to make 300kw going forward. A stock engine would be better for me.
I'd love 12k for it, and I'm sure you'll offer lower, the price may sound insane but keep in mind..
a) The BC kit alone costs $6000USD before shipping.
b) It's a legally registerable engine for those who are worried about RB30's engine numbers in engine bays.
c) It's already built, so no waiting for you
d) It's already running, come test it, drive the car, be sure about it without those post build worries and niggles that do appear at times.
So if this is something you wanted to build, well there's no way it's going to happen cheaper, faster and simpler than just taking this one out.
I could include photos of the build if really needed, but it looks like an assembled engine, unlike most, I went out of my way to not make it look interesting. No flashy rocker cover paint here.
Come drive the thing, test the thing, etc instead!
If interested, send a PM! Negotiations, swaps, etc all welcome.
  • Like 3
https://www.sau.com.au/forums/topic/468194-blueprinted-rb28-neo/
  • 1 year later...
This engine is still running strong for 25,000kms since I posted this.
Do you want a reliable forged motor for less than half of what it would cost you, about fifteen times faster than doing it yourself? How much assurance do you reckon you will get from old mate building your motor over the course of two years, for 20K?
Buy this instead. It works.
  • Like 1
Unfortunately not really as I would certainly die attempting to use such a bike, and as I know zero about bikes I'd have to sell it like a complete n00b in any case.
Do NOT get a bike
They take you with them when things break lmao
  • Like 1
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
