helloo!!
Hey guys, just joined up. Driving a white 33 40th ann with tasty bits thats super clean. pics to come. Interested in meeting up for a cruise next time one is organised if someone can point me in the right direction on this site that would be great. Cheers.
https://www.sau.com.au/forums/topic/468215-helloo/
On 12/20/2016 at 9:33 PM, hoonigan said:
helloo!!
Hi Wayne - if you want to meet up with fellow SAU people put your location in your profile.
https://www.sau.com.au/forums/topic/468215-helloo/#findComment-7800227
    • Car should sit at 12.2 or more, maybe 12.6 or 12.7 when fully charged and happy. If there is a decent enough parasitic load then it will certainly go lower than 12.2 with time. You can't beat physics.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue. Isn't 12v low, shouldn't it be around 12.5v?
    • Anything above ~9.5V is acceptable. The higher the better, but it will almost always drop to at least 10.5V, if not lower, even with a new big battery and everything else being good. 9.76 is not a concern. If it goes below 9, you'd be sure that there's a problem with either the battery or the connections.
    • It's new almost. Under a year old i think and I've tested it twice at supercheap
    • Glue the head from a Pez dispenser on it. Goofy, or Winnie the Pooh, so something.
