R33 21u stock turbo for sale, had approx 150,000km before taking out, run on 10psi max.
Has a slight amount of front to back shaft play but rotates smoothly and the blades are undamaged. Was working perfectly when it was fitted 3 months ago.
$200 negotiable
R34 turbo neo bottom end for sale.
This was bought off another forum member and i was going to use it in a rebuild because a tuner diagnosed my motor current motor as stuffed.
Didnt end up using it because:
1. My motor was fine. Tuner said no comp however i tested comp myself multiple times after that and it was ok.
2. Tuner told me to buy r34 block to rebuild r33 motor. I bought the block not knowing 33 head wouldnt be compatible with the neo block. I assumed since he specialises in jap cars and skylines he would have known this. Obviously i should have done my homework to check this instead of just assuming he knew what he was talking about
It is off an auto r34 turbo sedan that was completely stock. Looks to be in great condition. Unsure of the exact number of km to be honest but i was told it was under 100,000 and judging by the pistons and bores i would say its likely.
Have paperwork with the bottom end.
$550 negotiable
20161018_161742.thumb.jpeg.50375e6320e8120161018_161837.thumb.jpeg.84d574594715c20161018_161735.thumb.jpeg.1897fef5adaa020161018_161723.thumb.jpeg.49dfd88d17ee420161018_161713.thumb.jpeg.8c64c9c5daa9f20161018_161657.thumb.jpeg.ad7b6d92a90d1
  • 5 weeks later...
  On 21/01/2017 at 10:49 PM, Birds said:
Sounds like your tuner isn't too clued up!!!
Tell me about it.[emoji58]
It just shows you should ALWAYS do your homework when buying parts.
Even when the person telling you to buy works on and tunes skylines for a living.
  • 3 weeks later...
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
