R33 21u stock turbo for sale, had approx 150,000km before taking out, run on 10psi max.
Has a slight amount of front to back shaft play but rotates smoothly and the blades are undamaged. Was working perfectly when it was fitted 3 months ago.
$200 negotiable
R34 turbo neo bottom end for sale.
This was bought off another forum member and i was going to use it in a rebuild because a tuner diagnosed my motor current motor as stuffed.
Didnt end up using it because:
1. My motor was fine. Tuner said no comp however i tested comp myself multiple times after that and it was ok.
2. Tuner told me to buy r34 block to rebuild r33 motor. I bought the block not knowing 33 head wouldnt be compatible with the neo block. I assumed since he specialises in jap cars and skylines he would have known this. Obviously i should have done my homework to check this instead of just assuming he knew what he was talking about
It is off an auto r34 turbo sedan that was completely stock. Looks to be in great condition. Unsure of the exact number of km to be honest but i was told it was under 100,000 and judging by the pistons and bores i would say its likely.
Have paperwork with the bottom end.
$550 negotiable
20161018_161742.thumb.jpeg.50375e6320e8120161018_161837.thumb.jpeg.84d574594715c20161018_161735.thumb.jpeg.1897fef5adaa020161018_161723.thumb.jpeg.49dfd88d17ee420161018_161713.thumb.jpeg.8c64c9c5daa9f20161018_161657.thumb.jpeg.ad7b6d92a90d1
  • 5 weeks later...
Sounds like your tuner isn't too clued up!!!
Tell me about it.[emoji58]
It just shows you should ALWAYS do your homework when buying parts.
Even when the person telling you to buy works on and tunes skylines for a living.
  • 3 weeks later...
    • The cam I am actually putting in (a few posts up) is actually smaller than my current one. At least duration/overlap wise. All the chop stuff I hear just sounds like an engine running badly, because it is. I then envision driving it around in 1st gear and being massively sad about it bucking to the beat of said chop. There is an idle video of someone with a similar cam floating around the internet, but mine is a custom cam (so is his) so it'll never be the same, plus the fact exhausts are entirely different. What I want to do is put some bullet mufflers/race mufflers in to replace a couple sections straight pipes that currently replace the two extra cats that I don't need. But this is even further down the line!
    • I can tell you now, when the bracket that the little hydraulic ram attaches to snaps, with a subframe, and V8 from an AMG C63 on it, it sounds like someone letting shotgun off right beside you. It leaves your ears ringing, and a huge thankfulness that you never ever put a body part under something heavy that's only supported by a hydraulic lift...
    • Still not a guarantee fix. I used a high quality butyl-mastiq (the black goo that's not really silicone nor polyurethane, same stuff they use from the factory that just spreads out like melty cheese), and I still get lots of water on both sides of the trunk when raining or washing the car. I also suspect the factory spoiler rubber gasket might not be sealing well, so I'm thinking of adding a thin layer of grey silicone around the bolt holes on both sides and see if that's where it also leaks from. The biggest issue is that these cars don't come with a drain hole on each side like other coupes and hatchbacks.
    • I hate it, but maybe he could paint it Monster jam style and call it...godzilla?
    • Would seem to me to be appropriate to go GTR style bar. There are options with and without N1 vent holes, with the GTR lower lip integral (because FG copy). https://justjap.com/search?q=r32 bumper
