Misfiring help
I need help. I have a 1991 Nissan Skyline R32 GTR, I recently had it in the shop getting intercooler piping, new ECU HKS Fcon V pro and a tune. Got 579 to the wheels and was running great for about a week. Then one morning woke up and it sounded like a Subaru and it blows smoke out the exhaust. Did some trouble shooting and found that when I unplugged number 2 and 4 coil pack the engine idle didn't change. red out the coil packs and checked the plugs, all good. even swapped coils around with no change. The plugs are wet with gas so I did a old school spark test in the block and getting spark.  ordered new coil pack wire harness and still no change. swapped out the PTU(coil ignitor unit) with a known good one and still no change. Did the self diagnosis and got code 21, Could it be the tune is causing this, I mean it just started one morning when I started the car and it ran fine the night before. Thanks.
Mods on the car
1.2mm aluminum head gasket
tomei pons cams
tomei m8270 turbos
HKS intercooler piping
HKS boost controller
HKS Fcon pro v(no MAF's)
nismo 600cc injectors
walbro fuel pump
full 3in exhaust w/cat delete
https://www.sau.com.au/forums/topic/468232-misfiring-help/
Did you check to make sure your CAS is firing all 6 cylinders? May have a dead spot on it. Correct me if I'm wrong but firing order is 1-5 3-6 2-4, so the fact that 2 and 4 are wet would make me lean towards a bad cam angle sensor
Edited by Ed.williams5
https://www.sau.com.au/forums/topic/468232-misfiring-help/#findComment-7800061
Ok so new problem. I was going to take the car in to my mechanic and it wouldn't start. First time turned over and backfired,  after that just cranking, a little bit of sputtering like its going to start but nothing. funny thing is it started the day before no issues, besides rough idle due to my misfire. I didnt drive it, just started it and to go to the store then decide against it. Any ideas? I dont want to pay for a 22km tow bill.
https://www.sau.com.au/forums/topic/468232-misfiring-help/#findComment-7801289
On 12/29/2016 at 0:44 AM, mcdow991 said:
Not yet, was afraid it would mess wuth my timing, but now that it wont start im going to try that. Thanks.
Before you pull it just take a sharpie and put reference marks so when you put it back you no exactly where it was.
https://www.sau.com.au/forums/topic/468232-misfiring-help/#findComment-7801713
So I took my car to my mechanic and found out I have no compression in my number 2 cylender,  and my pistons are burnt on the exhaust side. Worst case senerio.  He believes that maybe the turbos, I have Tomei m7960. He said that he has other cars blow the bottom end using the same turbos.  Anyone else have any issues with them?
https://www.sau.com.au/forums/topic/468232-misfiring-help/#findComment-7803898
    • Well, back in the day..... "race" fluids, which were essentially only really "high temp" fluids, used to absorb water more readily. So they really needed to be changed more often anyway. The coincidence of that being directly necessary along with it being what racers would do as a matter of course was just fine.
    • Does the high temp fluid degrade any different over time compared to normal one? That's one thing I've always been wondering. Because a track car is going to get the fluid flushed probably way more often than every two years and will see less kilometers driven. I would think the requirements are different. I'm running Motul RBF 600 in mine. Was recommended by my mechanic before a trackday and I've stuck with it since. Hasn't seen the track since but I've kept buying and using it for servicing anyway.
    • The brakes are all stock bar some DBA slotted discs and the EBC pads and braided lines. The car has brake ducts as standard but they're kinda pointed in the general direction of the brakes rather than really getting at the heat source. I guess I should hit it with an infra red thermometer after a session and see what they're at.  100%! Its just a curiosity more than anything. As I said, high temp brake fluid was such a track day rage back in the day. From people I speak to at the track and threads on here everybody has their own take on it but I'm not gonna scoff at spending a few more bucks.    OH, a quick side question - would you use brake fluid from an opened container even if the lid has been on? Eg, if you have a bottle that you opened last time you flushed, it's been tightly closed, is it still good?
    • Nice, is there a post with the new 4" dyno curve?
