Misfiring help
I need help. I have a 1991 Nissan Skyline R32 GTR, I recently had it in the shop getting intercooler piping, new ECU HKS Fcon V pro and a tune. Got 579 to the wheels and was running great for about a week. Then one morning woke up and it sounded like a Subaru and it blows smoke out the exhaust. Did some trouble shooting and found that when I unplugged number 2 and 4 coil pack the engine idle didn't change. red out the coil packs and checked the plugs, all good. even swapped coils around with no change. The plugs are wet with gas so I did a old school spark test in the block and getting spark.  ordered new coil pack wire harness and still no change. swapped out the PTU(coil ignitor unit) with a known good one and still no change. Did the self diagnosis and got code 21, Could it be the tune is causing this, I mean it just started one morning when I started the car and it ran fine the night before. Thanks.
Mods on the car
1.2mm aluminum head gasket
tomei pons cams
tomei m8270 turbos
HKS intercooler piping
HKS boost controller
HKS Fcon pro v(no MAF's)
nismo 600cc injectors
walbro fuel pump
full 3in exhaust w/cat delete
https://www.sau.com.au/forums/topic/468232-misfiring-help/
Did you check to make sure your CAS is firing all 6 cylinders? May have a dead spot on it. Correct me if I'm wrong but firing order is 1-5 3-6 2-4, so the fact that 2 and 4 are wet would make me lean towards a bad cam angle sensor
Edited by Ed.williams5
https://www.sau.com.au/forums/topic/468232-misfiring-help/#findComment-7800061
Ok so new problem. I was going to take the car in to my mechanic and it wouldn't start. First time turned over and backfired,  after that just cranking, a little bit of sputtering like its going to start but nothing. funny thing is it started the day before no issues, besides rough idle due to my misfire. I didnt drive it, just started it and to go to the store then decide against it. Any ideas? I dont want to pay for a 22km tow bill.
https://www.sau.com.au/forums/topic/468232-misfiring-help/#findComment-7801289
On 12/29/2016 at 0:44 AM, mcdow991 said:
Not yet, was afraid it would mess wuth my timing, but now that it wont start im going to try that. Thanks.
Before you pull it just take a sharpie and put reference marks so when you put it back you no exactly where it was.
https://www.sau.com.au/forums/topic/468232-misfiring-help/#findComment-7801713
So I took my car to my mechanic and found out I have no compression in my number 2 cylender,  and my pistons are burnt on the exhaust side. Worst case senerio.  He believes that maybe the turbos, I have Tomei m7960. He said that he has other cars blow the bottom end using the same turbos.  Anyone else have any issues with them?
https://www.sau.com.au/forums/topic/468232-misfiring-help/#findComment-7803898
    • It only looks tidy, as most of the stuff that was on the whole back wall, is now in the trailer to go to the tip, or has been shoved in my 2.2x2.4m "Spare parts room", and now I can't get to anything in there Ha ha ha I could definitely do with a bit more space, but I'd just end up with your problems I'm going to enclose the car port beside the garage, and move a lot of stuff into it I think. OR... It will be setup as a fabrication area, and the main garage will have parts storage in it. I'm not sure yet... Need some pictures of that big shed you've got with the bikes and Skyline in
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
