Would really appreciate feedback on any trusted business used in Melbourne for paint restoration on cars such as R34 GTR such as mine & maybe have dealt with Bayside Blue. My car is not bad to say the least, but has some little things such as stone chips, couple scratches, & couple pin dents-(may need good paintless dent guy also). Plus my TE37's(rims) could use a bit of a minor resto. Any suggestions? Thanks in advance
https://www.sau.com.au/forums/topic/468237-looking-for-paint-resto-r34-gtr/
I've heard rumours that really good professional detailers can get rid of most things like scratches & stone-chips, claybar etc. Some even do rims(except tiny dents, DT Panels or paintless dent maybe for those)??? The rumours could be wrong, although if anyone knows of any detailer/s such as this then please let me know. Cheers [emoji1417]
as my car is nowhere near in need of a respray
  • 4 months later...
  • 1 month later...
2 hours ago, Spec-s Gttt said:
Pratt do you know anyone who does custom body kit I have a r34 gtt I want the R34 gtr body kit carbon fibre bonnet
Do u want actual carbon, or is fibreglass fine, heaps of them available thru viva, also if you get the gtr bonnet chances are it wont line up with ur gtt front bar
Hey Spec-s Gtt,(my name's Phatt not Pratt haha). Vu is a wizard at fitting body kits-he fitted my body kit, Nismo front bumper & painted all-amazing finish. His shop is in Springvale & shop is called "DT Panels". MissGT34 is correct though.
Has anyone got a full respray from DT Panels? I'm curious on how much they roughly charge
Hey Luis32gtr. There was a midnight purple 2 r34 gtr getting full respray the other day when I popped in to DT Panels. In my opinion for the awesome work he does, he actually has very reasonable prices. He really looked after me. Give him a call, say I referred you(blue r34 gtr) from SAU, he should look after you too. Ps. I'm not letting anyone else touch my car cosmetically, & the previous owner of my gtr was the same
  • Like 1
Thanks alot phatt I appreciate the help
  • Like 1
  • 4 months later...
  • 2 months later...
I've been around a lot of pedantic finicky GTR-owners with mega dollar cars who have all gone to one person to do their work. I have too. Steve at SL Customs is second to none. No cheap or rushed paint jobs. Only show quality paint each and every time.  I can personally vouch for him as can a huge number of GTR owners across Melbourne. He started off doing show pieces in the muscle car scene and has done some very rare exotics. He's one of the few who can do a tremendous job on bayside blue and midnight purple and is usually booked out well in advance, so don't count on him squeezing your bucket with Chinese fiberglass in for a 'cheapy', if that's your thing :16_relieved:. He's not on these forums so PM me if you want more details.
+1 for SL Customs. I actually went out there to ask questions about front bumpers and honestly his pricing was pretty damn reasonable for the competency he was showing. Definitely worth a call/chat if you can book in advance.
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
    • I only recently purchased the vehicle, it came with the flex setup but the current tune is e85 only, which is why im wanting to get the tune redone to enable a mixture.  First i need to get the exhaust redone tho. I was thinking of getting a varex muffler but it sems they dont fit well in the 33 (hang low because of the valve mechanism which sticks out on top) and generally dont sound good. So that leaves me with redoing the entire exhaust (more resonators and mufflers) so its not a menace when i come and go from home, and then have the aes dump valve somewhere along the line to really open it up. I was thinking of having it before the cat but after seeing how insanely loud it will be (on a vl turbo) im thinking of putting it more towards the rear of the car, after one of the resonators.
    • At this point I'm just 'hoping' it's the turbo seals. I did speak to someone who said it's normal for these turbos to have a bit of axial play? Not gonna lie I've never checked a turbo for axial play before but you could hear it tapping a bit as I moved it back and forth. Surely that's too much? My theory is (could be completely wrong), bad axial play, worn bearings, bad seals, oil into dump/compressor side, burns in exhaust = blue smoke. On a timing belt related note, my crank pulley was missing that front plate that sits in front of the timing belt. It's that metal round plate. It did have the rear one, and the woodruff keys are in the crank which was nice. Can anyone confirm if the NEO det engine has a front plate, im sure it would to protect the front of the timing belt or something. Water pumps...the pump I got was an NPW (yes grill me if I should've got a genuine one lol). It has a smooth mating surface, kit came with a pretty pathetic looking paper gasket. Do I need to use any RTV or just trust the gasket will work because its a smooth mating surface? Cheers legends have a good Easter break!
    • Cheers man, I thought the same.   Bit of an update on it all. It was definitely blue smoke, not grey after all. It didn't really smell oily but it was blue after all. Also puffing just the smallest amount on idle with no throttle.   I ended up pulling the intake and exhaust off and there was around 3mm of axial play on the turbo shaft. So I figured we'll that's buggered and sent it off to get hi-flowed at hypergear. Haven't got it back yet.   I haven't compression tested it yet. Had a look in the cylinder and cylinder 1 spark plug, looked a bit sooty but not oily. Then I've just started doing my timing belt because it's age is unknown.
    • In that case it is probably stock. It lives in the navigator side footwell behind the plastic trim just in front of the a pillar.
