Would really appreciate feedback on any trusted business used in Melbourne for paint restoration on cars such as R34 GTR such as mine & maybe have dealt with Bayside Blue. My car is not bad to say the least, but has some little things such as stone chips, couple scratches, & couple pin dents-(may need good paintless dent guy also). Plus my TE37's(rims) could use a bit of a minor resto. Any suggestions? Thanks in advance
https://www.sau.com.au/forums/topic/468237-looking-for-paint-resto-r34-gtr/
I've heard rumours that really good professional detailers can get rid of most things like scratches & stone-chips, claybar etc. Some even do rims(except tiny dents, DT Panels or paintless dent maybe for those)??? The rumours could be wrong, although if anyone knows of any detailer/s such as this then please let me know. Cheers [emoji1417]
as my car is nowhere near in need of a respray
  • 4 months later...
  • 1 month later...
2 hours ago, Spec-s Gttt said:
Pratt do you know anyone who does custom body kit I have a r34 gtt I want the R34 gtr body kit carbon fibre bonnet
Do u want actual carbon, or is fibreglass fine, heaps of them available thru viva, also if you get the gtr bonnet chances are it wont line up with ur gtt front bar
Hey Spec-s Gtt,(my name's Phatt not Pratt haha). Vu is a wizard at fitting body kits-he fitted my body kit, Nismo front bumper & painted all-amazing finish. His shop is in Springvale & shop is called "DT Panels". MissGT34 is correct though.
Has anyone got a full respray from DT Panels? I'm curious on how much they roughly charge
Hey Luis32gtr. There was a midnight purple 2 r34 gtr getting full respray the other day when I popped in to DT Panels. In my opinion for the awesome work he does, he actually has very reasonable prices. He really looked after me. Give him a call, say I referred you(blue r34 gtr) from SAU, he should look after you too. Ps. I'm not letting anyone else touch my car cosmetically, & the previous owner of my gtr was the same
  • Like 1
Thanks alot phatt I appreciate the help
  • Like 1
  • 4 months later...
  • 2 months later...
I've been around a lot of pedantic finicky GTR-owners with mega dollar cars who have all gone to one person to do their work. I have too. Steve at SL Customs is second to none. No cheap or rushed paint jobs. Only show quality paint each and every time.  I can personally vouch for him as can a huge number of GTR owners across Melbourne. He started off doing show pieces in the muscle car scene and has done some very rare exotics. He's one of the few who can do a tremendous job on bayside blue and midnight purple and is usually booked out well in advance, so don't count on him squeezing your bucket with Chinese fiberglass in for a 'cheapy', if that's your thing :16_relieved:. He's not on these forums so PM me if you want more details.
+1 for SL Customs. I actually went out there to ask questions about front bumpers and honestly his pricing was pretty damn reasonable for the competency he was showing. Definitely worth a call/chat if you can book in advance.
    • As you're looking at using a Link ECU, then large injectors are not a problem. But there's not really any need to go 1000s on an RB20 unless you're planning >>600HP on E85, which would seem unlikely. There are other options for injectors. The Xspurt ones are available from a number of places and you can get them in the mid 600s and 725cc, which is probably a sensible place to be. These are all EV14 based. If you are not using the stock AFM (at all, which would be the case with a Link) then a large turbo intake pipe to suit the ATR turbos is not an obstacle, so you should use one instead of a highflow. Results will be better.
    • Hey guys,  I'm after some advice and this here is the best place to get it imo. I was a member a looong time ago under another account, with a lost email address. Its nice to jump back on and see some of the same names still giving good advice.  I mothballed my car when i moved to perth in 2013, and after getting towed across the nullabor a few times it has officially done more km's on a trailer than under its own power. Now that i have started the process of tidying up and modifying it, i see the fruit available (and the fruiterers selling the produce) is different than back in the day. hence my questions, as i used to 'know' what to get and now, i'm not so sure. Engine wise the car (92 gtst) has a walbro 255, k+n, fmic, cam gears and and turbo back 3"exhaust. Wish list is a Hypergear high flow or ATR43G1, Link G4x and some newer injectors before a tune up. My goals are modest, only low 200's power wise. i know i could achieve this with less, but i've been swapping out old for new where i can. Every cooling hose has been replaced, along with mani gaskets, WP, thermostat and radiator, fuel pump and timing belt, tensioner and idler, and i rebuilt the steering rack. Regarding the injectors, the fruiterers all seem to sell what used to be considered quite large injectors. There are a lot of options for bosch 1000cc EV14's, and i would like to know if that is a suitable choice for my build. Is modern injector design good enough to run these at the low duty cycles that i likely would be? is there a downside to running a too large injector these days? or, would there be an upside to running a smaller injector at higher duty cycle? I can see that there are smaller injectors still available, but the ones i have seen specifically marketed for RB's are pretty large (see: https://golebysparts.au/collections/fuel-rail-injector-kits/products/nissan-rb20-fuel-rail-bosch-980cc-1150cc-injectors-turbosmart-fpr800-regulator-kit), and i dont know enough about them to say one not marketed for RB's would fit or not. I have searched the forums, and amongst all the posts on older tech, I did see gtsboy recommend EV14's, but no size was mentioned... again, i'm not clear on if the smaller size bosch injectors are also EV14's as they do look similar.  also, if someone can recommend a tuner familiar with RB's in the Geelong or West Melbourne area i'd appreciate it. Thanks in advance guys. Cheers, Rowdy
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
    • I mean, if you were to move the jacking points away from the original location, that is, away from the wheels and closer to the centreline of the car, then it will be more likely to overbalance and tip off the supports. Same as we talked about before. I was talking about moving for-aft. If the sill is bent outward or inward, then the car would obviously look unstraight from the outside. Hopefully that hasn't happened either. Again, you can do comparative measurements from the chassis rails to see if there is much deflection.
    • Can you elaborate what you mean with your first sentence? I meant move as in the bulge kinda seemed like it got pulled "outward" meaning it got pulled down and to the side with the jacking rail itself, so the load bearing bulge now sits lower than usual and is not level with the sill on the other side of the jack point. Either that or the jacking rail just got pushed in a good bit.
