It will not work out of the box. You need to fit an IAT sensor and connect up a MAP sensor and ideally also (but not necessarily) a  solenoid for boost control. Then you will need at a minimum to set the ecu according to the injectors you are using and get a tune. You will not have an OBD port - it comes with a cable which plugs straight into a lap top.
https://www.sau.com.au/forums/topic/468266-r34-link-ecu/#findComment-7800561
Many thanks
So cannot plug it in and then do the rest? I can also buy the map sensor
The reason i am asking is so it gives me time to ensure turbo and everything else is working as expected before shelling out £500 for mapping
Also at the moment my boost controller sensor which i think does some task including playing with Air and fuel ratio is broken
I know this is bypassed and not needed in link so wanted to buy this ecu rather than wasting £150 on a sensor which i won't need soon
Car is running a bit rough
https://www.sau.com.au/forums/topic/468266-r34-link-ecu/#findComment-7800567
The ECU should have a MAP sensor in it. The G4+ i think has a 4 or 5 bar but the standard G4 is only 3 bar if i remember correctly. If you run a boost line to your ECU you can use the internal MAP sensor to get you going. I would recommend running an external sensor in the engine bay
I played around a bit with mine just to get it to run/drive so I could take it to get tuned. I have a wideband permanently mounted in the car though so could always watch it (mine was rich af on the link base map)
As above I would get a IAT sensor and boost solenoid. I have both on mine
https://www.sau.com.au/forums/topic/468266-r34-link-ecu/#findComment-7800574
Many thanks so essentially you managed to drive around by monitoring the a/f ratio on a wide band sensor?
Does the map sensor sit right before the air filter where current one is?
I guess I have to get a link map sensor , correct?
I believe there was a zx20 map sensor( if that is correct) which people used as an upgrade to standard one
Does the ecu need to be linked up to the wide band sensor?
https://www.sau.com.au/forums/topic/468266-r34-link-ecu/#findComment-7800579
I probably drove mine alot more then I should have untuned. So not recommending driving it daily like this but it will get you to a tuning shop if you don't go putting your foot down etc. I would want to watch AFR's, even though my car was rich, doesnt mean yours will be
MAP sensor can go anywhere, it just needs a boost feed. Mine is tucked up the rear right of the engine bay
I got a Link 4 bar MAP sensor but you may be able to use others
You dont have to hook the wideband up to the ECU but its better to for tuning reasons as well as some on built features of the ECU. You can run closed loop cruise to trim your AFR's when just cruising around sitting on a certain speed
https://www.sau.com.au/forums/topic/468266-r34-link-ecu/#findComment-7800582
You can use the built in Map sensor until you get a new turbo and then buy a bigger one - I used a GM 4 bar one. You can use the Link boost solenoid or just buy a Mac valve (the Link is just a rebadged Mac).
https://www.sau.com.au/forums/topic/468266-r34-link-ecu/#findComment-7800611
Does this eliminate the existing afr right before the cone filter?
If i understood correctly map sensor is better version of the afr which is on skyline and will replace it but i might be wrong
If i use built in sensor, i just need to get a cable from boost to ecu?
If I buy external one, where does it sit?
Is it anywhere in engine and running a boost line to it?
Do i have to do any wiring to link the external sensor to the link?
Sorry for many questions
I am getting very excited and about to buy the link next week after xmas
https://www.sau.com.au/forums/topic/468266-r34-link-ecu/#findComment-7800672
OK. Lets clear a few things up:
AFR: Air Fuel Ratio
MAP: Manifold Air Pressure
MAF: Mass Air Flow / AFM: Air flow meter
Air fuel ratio is done with a wideband o2 sensor (it is also done on the car from factory with a Narrowband sensor that is only able to read a 'narrow' range of A/F ratio's), this shows how much air and fuel have been used in the comubstion cycle.
MAP Sensor uses manifold pressure (boost/vacuum) to calculate engine load and how much fuel to add and what timing etc. MAF sensor actually calculates air flowing past a certain point to calculate the same things. For this reason MAF's are supposed to be more accurate (given everything being setup and running right).
O.K so with the Link: You CANNOT use the MAF that is factory fitted to the car (well there is no preset setup for it) so can ditch the factor Air flow meter that sits after the air filter and run a boost line (from the manifold - post throttle body, DO NOT run a line pre throttle body) to the ECU for your initial setup. The MAP sensor is built into the ECU so no wiring at all involved. The external MAP sensor can be placed anywhere in the engine bay but keep in mind you will need to run wiring and a boost line to this one. You can use the wiring from the Air flow meter (that you no longer need) to connect up the MAP sensor to the ECU. I would reccomend getting the XS (expansion) harness with the link. This allows you to have a few more inputs/outputs
This is a bad photo but you can see my MAP sensor in the background with the blue boost lines connected to it:
Another pic (Link Boost sensor on the right)
https://www.sau.com.au/forums/topic/468266-r34-link-ecu/#findComment-7800677
    • Hey all, not sure how active SAU is anymore but will ask away anyways. Just wanted to get some experience on the 2008 model GTR CBA model.  I've hit that age in my life (43) where I'm like fk it time to get my dream (midlife crisis) car. Looking at importing one in and seeing if these can be reliable if the main flaws are fixed up. Plan is to keep money aside to do the following straight off the bat to future proof it: * install a stage 1 rebuilt trans with all new bits and pieces.  * install a new Bellhousing from the later model GTRs. Or potentially an upgraded stronger version like MAD or ATR. Besides the above two things and typical maintenance items anything else you'd recommend doing.   Been speaking to a few people and the engine on these are very reliable apparently. But keen on the view of the community here. Hoping to find a nice grade 4.5 with low mileage in Grey. I'd go black but swirls too easy. Look forward to your responses and feedback. Cheers
    • Do Alan and Keith work on Skylines now? I remember buying stuff from them when I owned my Ralliart Lancer a few moons ago. Definitely genuine guys and be excellent if they dealt with the skyline platform as well.
    • Hey all, I'm Gaston from Sydney's West.  I was a member on here when I was a younger lad and owned a mint R33 GTS-T. Ended up selling it and getting married having kids (yadda yadda) we all know how the story goes. Now I'm back with the intention to get my midlife crisis (dream) car ... a R35 GTR.  You'll see me about asking questions and searching the forums. Good to be back and can't wait to get back an Import again.
    • I have to put something here in order to post the photos. From what I could gather there's more enthusiasm for modified cars now than there has been for years. There were probably more younger people there than older (me included lol) which was a good sign.  It did seem like the record least amount of representation of the 90's era hero cars on display though. Like maybe one or two examples of S-chassis Nissans, and maybe 3 or 4 R-chassis. By comparison there were a lot of Civics from that era but in all there were about 10 - 12 EG/EK Civic Type R.  Euro exotics are always there in large numbers, led by Liberty Walk...... say what you will about kids using markers to scribble on a Ferrari F40, it did seem like a stunt to infuriate Ferrari enthusiasts, or Ferrari itself. I wonder if there's something more to it. Either way LBWK have done some heinous things to a Lamborghini Miura this time. They should stop now.
    • Engines and drivelines are not war stoppers for me mate, busted arse bodies and un-obtainium parts and panels are though Both cheap Brumbies I looked at had trashed tubs and a fair bit of rust
