i'm doing the oil drain and where it bolts into the block the fitting is on a downward angle probably 30 degrees or so
will this be ok?
also will i need a fire insulation around the braids oil drain line if the line passes through the warped 6boos manifold?
the following is the angle it sits on the block
the box is the engine angle
IMG_1482547386.278512.thumb.jpg.e4760c36
https://www.sau.com.au/forums/topic/468272-is-this-angle-oil-drain-ok/
A little bit of oil will sit in the bottom of the bend as it sits lower than the hole in the block but it shouldn't be a problem.
Definitely heat wrap the hose so you don't end up with oil going straight onto your exhaust when it burns through.
