These NGKs have been in my Bora for only 20,000k's or so but the car has some small misses under load.
I took the plugs out to blast the carbon off with a torch but they were in pretty good nic and didn't need to be blasted.
20161226_151942.thumb.jpeg.b6696477b28f7
I gave them a little blast but then I noticed that some plugs are missing their tips which makes the gap bigger. In my humble opinion this could be what is causing the miss. What do you think?
20161226_153908.thumb.jpeg.ce09c6e15d533
https://www.sau.com.au/forums/topic/468296-do-i-need-new-spark-plugs/
You definitely need new plugs. Just looking at the pics they seem to have a massive gap - have you measured it?
Did you pull all six plugs? I have just acquired a V6 Camry and decided to replace the plugs only to find different plugs on the rear bank - I would say the last shop to service it didn't do the rears because they are a pain to get at...or is that not the case on your Bora?
2 hours ago, admS15 said:
The plugs without the tips are definitely your problem if they are the same part no. As the other plugs. Time for replacements.
Yeah, only 2 have the proper tips. Out of 6. A bit irritated as they were $30ea only 20,000k's ago. :(
No, I replaced these myself with the NGK platinums. 4 of the 6 are missing the little extra tip.
I might get Bosch plugs next time. Theres not many options for my car, but i'm a bit bummed by the NGK's.
