Here's my situation.
I had to put a new clutch in my 33 gtst.
I have the front of the car on stands and the back on the ground. New clutch is in and alligned with tool supplied. I have a trolley jack at the front of the box and rear of the box.
As I'm trying to get the input shaft inside the clutch I'm just missing out (half of the input shaft). I can't go up with the box anymore cause it's hitting the tunnel (if I went up the input shaft would be in). I have rotated the box up so the stater part is towards the bonnet.
Anyone have any tricks of the trade or done this before to give some ideas?
Thanks
https://www.sau.com.au/forums/topic/468312-refit-gearbox-help/
Do you have the front of the engine jacked up so the back is lowered? This helps with angle. Should allow you the room you need to get it in. If I'm having troubles I get someone to get inside the car and throw a rope or tie down around the back of the box and then remove the jack from the back of the box and get the person with the rope to adjust the angle as needed while you manhandle the box from below. It should go in the right side up. Good luck.
Don't forget to disconnect the exhaust or it will be trying to hold the engine straight. And drop the front subframe bolts down so the engine can tip back further. The input shaft can only ever go in when it is straight to the crank
Pig of a job with one person on the ground....going to need lots of patience
I havnt tried Adam. I plan to give it another crack tomorrow.
Cool, as stated above, patience is required. Everything has to be 100% lined up for it to go in and then it will pretty much just fall into place. If it won't go, step away for a while, clear your head and try again later.
Where did you jack the motor up from exactly?
I put a block of wood under the front lip of the sump and jacked it from there.
I jacked the front of the motor up, input shaft went straight in!!!! (f**k yeah)
Then i was having trouble getting the splines to line up so I took the jack out of the motor and she went straight in!!
Thanks for your help!!!!!! (I'm so relieved)
  • Like 2
No probs mate, it's a great feeling when it finally goes in. Congrats on completing one of the worse diy jobs on your car. Enjoy the new clutch[emoji106]
    • It's the adhesive holding the ceramic wheel to the shaft the fails on 90% of them.
    • Foreign debris, physical shock, boost leak, could be anything honestly. The danger in taking all the timing out of a tune/hitting the R&R corner is that even if the engine doesn't detonate your turbo is taking a lot of abuse from high EGT. Also, even if nothing goes wrong it is a journal bearing that is spinning at 100k RPM on boost. Eventually it goes through enough cold start/pressure cycles to wear it out.
    • I kinda accidentally saw this, and was interested, but It actually seems to replaces the whole center computer, using the existing screen and buttons. AND it may only be for a G37 and not compatible with a Japanese 370. So its not for me, but someone else may be interested to look into it. Its about $680USD. If I am understanding it right, it basically replaces/installs and android pc that integrates with the existing screen. But I could be wrong. https://gromaudio.com/vline/ The video I first saw was the following, with very little and unclear details.     Even if your not interested in the system, the video on their site was pretty comforting in showing how simple the whole centre comes out
    • hfygrte52 what side you looking for? Do you care what color car it's off? Found a white LH side on here: https://skylinespares.com.au/product/nissan-skyline-r33-coupe-rear-tail-light/   Aussie parts place but will ship to USA. Maybe get it before there's a tarrif on 25yo shit box parts
    • I’m with Shannon’s for all 5 of our cars. Agreed values seem fair, premium price is okay. ($210 ish a month, all comprehensive).  Have claimed once with them for a not at fault claim with another car where my car had no damage. Was one call after the incident and an email after. Deemed not at fault so premium didn’t go up either.    I have called up and spoken with people who are not familiar with certain cars and didn’t agree with me on value or let their personal vehicle preferences effect the call. But called back later and got someone else who was more agreeable.
