Here's my situation.
I had to put a new clutch in my 33 gtst.
I have the front of the car on stands and the back on the ground. New clutch is in and alligned with tool supplied. I have a trolley jack at the front of the box and rear of the box.
As I'm trying to get the input shaft inside the clutch I'm just missing out (half of the input shaft). I can't go up with the box anymore cause it's hitting the tunnel (if I went up the input shaft would be in). I have rotated the box up so the stater part is towards the bonnet.
Anyone have any tricks of the trade or done this before to give some ideas?
Thanks
https://www.sau.com.au/forums/topic/468312-refit-gearbox-help/
Do you have the front of the engine jacked up so the back is lowered? This helps with angle. Should allow you the room you need to get it in. If I'm having troubles I get someone to get inside the car and throw a rope or tie down around the back of the box and then remove the jack from the back of the box and get the person with the rope to adjust the angle as needed while you manhandle the box from below. It should go in the right side up. Good luck.
Don't forget to disconnect the exhaust or it will be trying to hold the engine straight. And drop the front subframe bolts down so the engine can tip back further. The input shaft can only ever go in when it is straight to the crank
Pig of a job with one person on the ground....going to need lots of patience
I havnt tried Adam. I plan to give it another crack tomorrow.
Cool, as stated above, patience is required. Everything has to be 100% lined up for it to go in and then it will pretty much just fall into place. If it won't go, step away for a while, clear your head and try again later.
Where did you jack the motor up from exactly?
I put a block of wood under the front lip of the sump and jacked it from there.
I jacked the front of the motor up, input shaft went straight in!!!! (f**k yeah)
Then i was having trouble getting the splines to line up so I took the jack out of the motor and she went straight in!!
Thanks for your help!!!!!! (I'm so relieved)
  • Like 2
No probs mate, it's a great feeling when it finally goes in. Congrats on completing one of the worse diy jobs on your car. Enjoy the new clutch[emoji106]
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
