Electric fan question
Hey guys have a question that's been covered before but I haven't had any luck when searching for the exact answer to my question.
Currently have a 14" puller wired to a switch I have to manually turn on and off on my radiator (was on the car when I got it).  I want to switch to a dual fan setup and run it off a temp switch.  My question is if I use a controller like the spal where can I pull signal from without having to chop the upper rad hose and using an adapter?
Is there a plug I can tie into for the command for the viscous fan to engage to use as a trigger wire for a relay to kick my electric fans on?
https://www.sau.com.au/forums/topic/468315-electric-fan-question/
There is no plug for the viscous fan. It's viscous, not electrically operated. You will need to install a thermostatic switch to turn the fans on and off. You can buy just a switch that has set on/off values instead of using a controller. The switch can be placed in the radiator or tapped into the housing for the top hose. Easiest way though is the adapter spliced into the top hose.
  • Like 1
Nlsmo6 thanks for the reply. Theoretically couldn't I pull the bleeder screw on the top of the intake manifold and put the switch there? Not too keen on putting an adapter in the upper hose as I think it will look tacky
You could if you retapped the hole. Smallest temp switch thread size you'd easily find would prob be 1/8 npt. Should still work fine from there and probably be more accurate as it's mounted on the engine itself. But bleeding might be a bit annoying pulling out the temp switch but pretty much the same I guess. Could even be a bit easier to bleed actually, cause the hole is bigger.
I was thinking rather than use the bleeder if I could either tap this elbow or weld a bung on and put a thermostatic switch on the end of it. Thoughts anyone?
Edited by Ed.williams5
    • I’m hosting a bunch of execs in the McLaren box on Saturday. If you’re around I’ll come say hi, and see if I can sneak out some freebies.
    • Yes. All of this. But even when you get the NOx as low as you can go on an RB, it will no doubt still be way too high. Same with CO and HCs. The tech and the tuning time just isn't there.
    • Dang. I love the little 'oil used' bingo card on the side.   🤣  Well, now they can use a box and an oil-filled goon.
    • Many many moons ago, I was chatting with Andy Wyatt, about his auto ignition tuning. One of the HUGE things he said to me, when tuning for power, right where you hit peak ignition timing for your max torque, dramatically increases NOx emissions. He was finding in testing, particularly on engines you could advance timing beyond peak torque, that backing the ignition timing off a couple of degrees only made for a small drop in torque (compared to if you keep backing it off further the same amount of degrees) but dramatically reduced NOx emissions. I'd say targetting for 14.7, and he's even mentioned in some scenarios going slightly leaner, and pulling a few degrees of IGN timing will help pass for emissions quite a lot. However, who tunes an RB for emissions
    • The main stuff from.Vibrant I see is more their intercooler piping, and everyone raving about their clamps, but when I looked it was about $150 per clamp... I was a bit   I also thought the public price SP had up was high. As Mark said, a normal exhaust shop can fab them. It was many years ago that I had a full exhaust built, but for a full turbo back exhaust, and 2 custom built mufflers, plus a high flow cat, was about $1,100, and that was fully installed, drive in, drive out. I believe SP was about $900 for 2 mufflers, just supplied   These days, I just buy the material and built it myself, because I need to stretch my $$$
