Help with Series 2 tail lights and trailer wiring
Anyone else have a grinding issue changing from 5th to 4th gear. I have no issues 3rd to 4th and 4th to 5th. But the car seems to grind a little when I do 5th to 4th … is this a common issue? Had it from the last owner. Bit annoying as I can’t hard shift down. Feels like I have to push a little to the left to get it smoother into gear. thanks
I would, especially if the car has had a few start ups or short trips to move it around But then I'm anal as fark about oil changes, as oil is cheap, and servicing is fun.....
These are still here, but, when I sell the SS they will go with it if not sold prior
As someone who has had a car sitting for a year... would you change *that* oil? It's still sitting in a container, right? If oil is fine in a shelf, is it not fine in a sump? I assume this is something specific to the oil being *unused* (i.e on shelf)
Wow.. I literally just refreshed my oil with oil from a 20L mini drum that's probably about 5 years old. It will get a thrashing in a couple of weeks on the track too. But hey sure, if you want to discard new oil, thwn go for it.
