On 12/27/2016 at 4:53 PM, dyl33 said:
Never made a snowman :( been sunburnt though.
Civic sounds like the better car,  1. It still drives with 372,000km  2. It doubles as a snowmobile what more do you want.
It has been a very reliable car to say the least, still on the original clutch!  Just had to use the snow blower to clear out another foot of snow this weekend:mellow:
https://www.sau.com.au/forums/topic/468327-withdrawl/#findComment-7802106
  • 1 month later...
Yeah, heat is good, I don't mind the dry heat, good swimming weather.....but the humidity this year has been hard to put up with.  If I wanted humidity I would live up north ffs.
And you can stick your snow [sorry Josh]....I live near it [aussie style] and hate the stuff, PITA.
https://www.sau.com.au/forums/topic/468327-withdrawl/#findComment-7811513
  • 10 months later...
I guess on the bright side, every Spring thaw must be like Christmas since you get to pull the wrapper off the GTR again. Driving the Civic would be like a reset button on your concept of a quick car.
You could always pick up a G35X for some quick(ish), cheap(?) Winter thrills.
https://www.sau.com.au/forums/topic/468327-withdrawl/#findComment-7863951
I used to drive a modded Subaru Outback turbo for a daily but now I drive over 1000km a week so I got myself the hand me down civic from my father when he bought a new one but then I got tired of fueling up twice a week so I bought a beat up tdi Jetta wagon that's coming up on 500k km but goes almost 1200km a tank. Now its to damn cold to work on the gtr, the engine needs to come out to get the shortblock rebuilt with some forged bits and new bearings. Then after that's all done I have a pair of -5 turbos and all the supporting bits to go on.
https://www.sau.com.au/forums/topic/468327-withdrawl/#findComment-7864235
    • Hi. I need a new clutch for my gearbox. It is a factory smallbox behind RB20DE NEO. What options do i have? If iam not mistaken the gearbox should be the same as in R32 GTST and Nissan S14/S15? I found some Xtreme Clutch Stage 1 for S14/S14 (i dont know if you know the brand) (UK) OR...is the clutch same as in the bigbox from RB25DET?   Thank you!
    • Listening to an artist called "the flashbulb". Not bad. Makes some fairly well researched youtube vids in various things.
    • Is actually easier than you might think. Assuming you have a spot, youfab up the branch, then just hang a longer than you can fit length of pipe down from there, and chop bits off piece by piece and decde which length was the quietest/nicest, then just put that length up in the place where it will fit. Clever folk can actually make like a trombone slide type arrangement so you can just play it like an instrument to find the best length.
    • Buy her some ear plugs.   Or, wear earplugs so you also can't hear Jackie whining...
    • Necroing this thread in 2025 to say thanks! The Manual for the m60 still has the wrong instructions and says to only press button 2 with ignition on. You are a champ, thank you.
