C34 wesh plug mod
Hi all. I know it might have been covered before i just don't have the time to look on all the pages.
I have a s1 c34 and am looking to do the wesh plug mod. The shop i am going to has done s2 but is unsure if s1 is the same.
I can't be with out a car if its different to do.
So question is are they the same part and way to modd as s2?
https://www.sau.com.au/forums/topic/468332-c34-wesh-plug-mod/
As far as i am aware through extensive research, no one has done this to their s1. I contacted the two who have done the plug mod on their s2, one originally from aus, the other from the uk, and both boxes were still going strong.
Now.. I spoke to a local trans specialist who used to do work on the re4 and then grew his business and now works on amgs bmws porches etc . He was against doing these 'mods' like shift kits, plugs, these days as it puts too much strain on other components. Once you have fixed one problem, another will arise as it is now the weakest link. He went on to say that once it starts slipping with more power just buy new shift solenoids. From there you are better off buying a stronger transmission.
I had my car tuned around a year and a half ago, I'm not using the retard function on gear changes and the box has never slipped once from doing this. Box feels extremely tight and shifts a lot faster than standard. I wouldn't be surprised if it could handle 50+ more kw with no problems as a street car.
On std tune In 30 deg weather on throttle for about 30mins would cause the box to slip. I haven't been able to make my box slip since it's been tuned.
I posted all the information and lingo used in our conversation roughly a year ago along with his workshop number as he had great prices on the solenoids. I can't find it, but maybe with some clever searching you can :)
I am far from a trans specialist, but i took his word for it as he has seen it all.
  • Like 1
Its not too expensive to do the whole shift kit from MV (or equivalent) while you're at it. You have to remove the valve body anyways to put the welsh plugs in the accumulators.
1st to 2nd may be a little abrupt most of the time, but once you're on the move the downshifts are so much more satisfying. Easily beats many modern vehicles.
Id echo what Tom says, the gearbox in standard form can slip due to heat and even between different fluids. The valve body mods eliminate all those issues, assuming the material on the clutches are still in good condition
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
