Okay so the first time it started to misfire and throw the error code 21 I swapped the OEM coils out with brand new yellow jackets coil packs and replaced the spark plugs with brand new NGK iridiums at approximately 80,000ks. The yellow jackets stayed in the car for around 10,000ks until the car started acting up again. I contacted the supplier and they had informed me that they must have had some kind of malfunction, I sent them back and had another brand new set sent out to me under warranty. Had the new set installed and the issue was fixed again.. until now...
I have now done approximately another 10,000ks and the problem has arisen again. The car is a 1999 r34 25gt-v (rb25de neo).
I bought the car with 77,000ks on the clock and since then I've only driven around 30,000ks. It now sits on 113,000ks.
Is there anything that would be contributing to the coil packs failing? An underlying problem perhaps?
Anyone with similar issues?
https://www.sau.com.au/forums/topic/468341-help-coil-packs-keep-failing/
Your problem is the coilpacks themselves. The yellow jackets are known to give trouble. You should contact the supplier again as he constantly tells people on this forum that his coilpacks are good and he has the best customer service, support and warranty. @performancewise
  • Like 1
Actually the last time I dealt with @performancewise it was a really unpleasant experience. I found the supplier to be extremely rude, ill mannered and extremely difficult to talk too.. I'm sure at some point in time I was actually threatened.. on top of all of that the product doesn't even work as it should. We exchanged emails for a period of time until eventually he gave in and sent me out the replacement set that I desperately needed. Now that it has happened again I don't think that I want to go through the whole process and then keep repeating the process every 10,000ks because of a junk dodgy product. I would much rather stay clear of @performancewise and their dodgy scam. I would encourage anyone thinking of buying yellow jackets to definitely re-think their options!
  • Like 1
2 hours ago, er34gtv said:
I'd still like to explore this topic, so if anyone else has any thoughts on the subject please let me know.
What do you want to explore?  There are many cases of Yellow Jackets failing although presumably many have not.
Buy OEM coils or Splitfires or step up to LS2 Truck coils or something like AEM coils.
Was just curious to explore the chance of something else setting the coil packs up for failure under the presumption that the new yellow jackets couldn't possibly of failed again after only 10,000ks. However I seem to be proven wrong as after more and more research its looking like the yellow jacket coil packs are the problem themselves. Will definitely be going with splitfires or ls2 coils the next time around.
They said yellow jackets never fail. That's there were no reported cases...
@performance-wise
Surely he will help you out.
That's what I heard too haha.. Im now thinking all the hype was driven by @performance-wise himself in an act to market his product and uphold some sort of reputation.
The only possible way @performance-wise could help me out is by fully refunding me the total costs of the coil packs. I would not dare go near another set of yellow jackets as I can't afford the added mechanic bill every 10,000ks and I certainly can't afford my car being off the road as its my sole form of transport.
I was being sarcastic lol.
There was a huge discussion a few months ago driven by @performace-wise. But alas he doesn't care about the negatives. Only the success stories.
You're better off going split fire coils. Drop in and don't worry.
  • Like 2
ohhh that is gold. I mean hey dude, sorry to hear of your issue, but another customer confirming the shiteness of the operation; I am glad people speak up about this, so good sellers succeed and bad ones GTFO>
  • 3 months later...
Thanks for everyone's recommendations. I went with the Splitfires in the end. Got them on an eBay auction for $400 including postage. Installed them myself. Definitely recommend going against the yellow jacket brand for anyone looking for new coilpacks. After countless hours of research and plenty of first hand experience they have proven to be straight poo.
  • Like 1
Somebody should set up a poll:
I have Yellow jackets that work
vs
I have yellow jackets that worked once.
I had my own intimate 'buying experience' with performance-wise some years ago - it wasn't coil packs though.
  • Like 1
On 01/04/2017 at 10:10 AM, GH05T said:
yeah, i dont mean to be "that guy" but i dont know why we still have them pushed commercially on these forums.
 Because we aren't allowed to post up negative experiences with any company or product on the forum, only positive
    • If you don't touch the CAS, then you're fine.
    • Yeah, my moulds and seals are 32 years old now. I think I will continue to not use a pressure washer on it.
    • I hear the old "I'd never use a pressure washer on my motorbike" BS in the dirtbike community too.  The only people that have had a problem from using a pressure washer on anything are the people that aren't using them properly.  If you hold the wand any more than 45 cms away from pretty much anything (radiators, wiring connectors, paint, etc) you aren't going to cause any damage.  We've had detailers wreck moulds and seals on cars at work before and the only reason why is they held the pressure washer too close and on the one spot for too long.  If you have 5% more brain power than a detailer then you know not to not do that and you'll never have a problem.
    • I'm pretty much healed up post surgery so I spent another almost full day out in the shed re-arranging everything to make room for all of the shit that I've taken off the car.  I need to get everything off the floor and away from the car for when I start making a massive mess stripping off the remaining body deadener and then for the the painting process.  Almost got the shed to a point now where I feel I can actually start working on the car again (clean shed clean mind or something!).  Almost 11 years of accumulated car parts, building supplies, tools, junk, etc have taken a long time to get in some sort of order again!  Most stuff is now boxed up and in the back shed if it's not car related.  Most people would still be horrified walking into my shed but it's significantly better than it was before!   For those that saw my separate post the other day, yeah I ordered one.... This version- I convinced myself to stop being a clown, wake up to yourself and realise it will take you 5 weeks to make one by which stage you're over working on the car again...  Maybe I am getting on top of my "mental ailments" and making smarter choices.... $1450 delivered which will take my miserable half-dutch arse a few days to get over having spent that much!  If I don't have a use for it straight away after my car is off it I might even see if there is a "rental market" for them.  See if anyone wants to hire it for a period of time.  $25 a week or something like that.  I'll worry about that when my car is actually ready to come off it though as that might be a while away!! There's now no excuses now for not ending up with an underside you could eat off! Away for kids sport the next few weekends so hopefully can get the rotisserie assembled ready to go for the car to go straight on it the next available weekend.
    • I always use my Karcher, but it's only a little one that I picked up from Supercheap  The only issue I ever had with a pressure washer was when I was a kid cleaning coaches, they had a hi-po industrial sized petrol jobbie that would strip paint if you got to close I saying this, we have a fairly high power washer at work with a diesel powered heater that sprays water at about 60°c, it works great for removing old wax and road grime on the underbody after some foam cannon action, albeit from a "stand off" distance of a few feet
