R34 gtt screamer dump divider
Divider in screamer dump?
Hey guys and girls, new to sau and wanting to pick some brains about a question i havnt been able to find the answer to (or maybe just havnt looked in the right places).
i just installed a screamer dump pipe to my 34 gtt but when i was installing it i found that the divider that came with it needed a bit of machining to fit into place inside. So i just took it off and am now running the screamer without the divider piece, other than being louder 24/7, will it harm my turbo in anyway?  Any info or knowledge will be awesome cheers
https://www.sau.com.au/forums/topic/468355-r34-gtt-screamer-dump-divider/
Thanks bro,
and yeah im going to put the divider back in once i get my hands on the table grinder to take the sides back a bit.
But in your opinion is it worth keeping the screamer? Is there any real advantages with keeping it on? As i only put it on because my mate had a brand new one sitting in his shed and i thought i may aswell see how it sounded.
Lose the screamer. Illegal and not worth the hassle. If you have a good flowing exhaust system of a size suitable for your power level you won't notice any difference. (your turbo should be fine).
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
