R34 25GT-FOUR
Hello everyone, i have been looking up some information on a R34 25GT-FOUR that i might be buying soon, the question i'm trying to find an answer to is the AWD system, is a the same setup as a torque split or is it always in 4wd mode. A few sources have said its always in 4wd mode and others say its 2wd until traction is lost. What makes it more confusing is that it is running a R33 RB26DETT engine with a R32 gearbox.
Thanks
https://www.sau.com.au/forums/topic/468359-r34-25gt-four/
The R34 atessa is always on - supplying 5% to the front until the computer tells it to increase it.. Despite the fact that it has an R32 box (why??) it will not behave like an R32GTR where you can disable the awd by pulling a fuse. If you want 2wd you can drop the front driveshaft or there is there a procedure you can go through which is not simple.
https://www.sau.com.au/forums/topic/468359-r34-25gt-four/#findComment-7801526
Awesome, thanks. I'm not to sure why it has a R32 gear box, it used to be a RB25DE auto and has been converted to manual, which also brings up another question. At the moment the speedometer is not reading the correct speed and the cluster is still the auto cluster, replacing the cluster with a manual wont fix the speedometer problem? I'm assuming that ill need to get a speedometer corrector installed.
https://www.sau.com.au/forums/topic/468359-r34-25gt-four/#findComment-7801528
Probably the speedo is wrong because the speed sensor pinion from the gt four wasn't fitted into the R32 gearbox. The gt four has 4.34 diff gears, whereas gtr has 4.11, so you need to use the correct speedo sensor pinion.
I have a R33 gtr gearbox in my R34 gt4 - in fact you can swap an auto 4wd gearbox speedo sensor into the manual box. This is what i did.
In other words, you need the R34 gt four speed sensor, to match your diffs. Note that I'm assuming the car has kept the 4.34 diffs, not swapped to 4.1. Either way, they just have to match.
https://www.sau.com.au/forums/topic/468359-r34-25gt-four/#findComment-7801538
I have read varied opinions regarding whether the factory electronic sensor from R33/R34 will or won't fit into the R32 box. I haven't tried it. Did some research though, the speedo drive gear on the output shaft is the same, R32 to R33. I think even the rear housing is the same.
Also, correcting myself from above, GT four is factory with 4.363 gearing.
https://www.sau.com.au/forums/topic/468359-r34-25gt-four/#findComment-7801749
  • 1 month later...
    • Nope, but they are definitely one of the default choices. Well established.
    • Has anyone used > https://performancecoating.com.au/
    • Haha actually I did join back then under a different email address,  I couldn't re-activate my account so made a new one! I didn't post much anyway so not missing out on much. Amazing to see how the value of the cars and parts has changed over the years, also ACT section appears to be dead now.
    • Thanks... It's in pretty good condition overall, probably due to not being drifted/tuned however being a daily driver has taken its toll. Had 100k on the clock when I got it, up to 180k now. Unfortunately it's not 100% dent free, it's got a small dent on FLH side and broken indicator from where I hit a small kangaroo at high speed. If you look at closely at pic #5 you might spot the dodgy trailer light repair my old man and I rigged up as temporary repair! - It's still there due to a combo of needing the car as daily driver and then too lazy/busy to fix properly. I've a couple of other minor accidents accidents as well but nothing major. One required a new front bar and unfortunately the smash repairer ordered the normal gtst one and not the aero bar. Needed the car back asap so just went with it, regretted ever since.
    • I can't believe that anyone is foolish enough to believe that the base maps are for any other purpose than to drive the car up onto the trailer/truck or gently creep it to the dyno. No matter how good they are, they can never be any better than the factory maps**, and only the foolish trust those on a significantly modified setup. **Yeah, yeah. I know there's also the difference between factory maps being fixed to certain injector sizes and MAP/AFM/VE relationships, and the likely aftermarket ECU base maps being better able to handle the sorts of changes that would render a stock ECU dangerous, like different sized injectors. But let's just ignore that for the moment, because the principle is still the same.
